Author Topic: REMOVING THE FRONT BAODY COVER HELP  (Read 9884 times)
feebleknievel
    • Kickin Country hITS
« on: October 22, 2013, 03:55:42 PM »
i've got s ervice manual it shows the screws to remove but that's as far as it goes.it don't illustrate it comming off anyone know of a good way so you don't break something
feebleknievel
Re: REMOVING THE FRONT BAODY COVER HELP..OK I GOT IT OFF
« Reply #1 on: October 22, 2013, 04:31:01 PM »
ITS OFF
de-dee
« Reply #2 on: October 22, 2013, 07:39:24 PM »
   that little Y section you tooki off, put a little lube on the rubber to make it easyer to take off next time, they break off very easy,
kayakbuilder
« Reply #3 on: November 11, 2013, 05:41:36 AM »
What is the trick to removing the front cover?  I tried, but was unable to figure it out.  The manual wasn't much help.  The downtown is much harder to remove the body panels than either of my Yamahas.
'13 Downtown 300 White
'08 Yamaha Zuma Raven 70cc BBK, LV ZX Exhaust, CF Reeds, Sport Windscreen, SOLD
'99 Yamaha Zuma II 70cc BBK
James 1:27
Gilesplus
Re: REMOVING THE FRONT BODY COVER HELP
« Reply #4 on: December 29, 2013, 10:47:21 AM »
Having just done this I found the most help here: it's not in English, but visually it's quite helpful, although some of the shots are quite dark!
From memory you have to remove the windscreen, the coverings under the footrests/ running boards, as well as a bunch of screws, and as mentioned above, under the windscreen, between the headlights there's a Y shaped piece of black (on my black and white one it's black) about 20cm/10" long that you have to carefully pull out horizontally. Under here are a couple of nuts that help release the front fairing. I'll try to attach a couple of photos later on to help, I was installing a thermometer on the handle bars.
Good luck !
Philly
« Reply #5 on: December 30, 2013, 03:53:39 AM »
Just watched that you tube video and that seems like a lot of work to get to the front headlights to change a bulb. I've never had to change one yet and I didn't think it was so involved. My Yamaha BWS125 was easy to do.
mnpugdog
« Reply #6 on: January 01, 2014, 01:41:38 AM »
I see no reason to remove the lower side panels.
mjrii87
« Reply #7 on: March 05, 2014, 09:57:12 PM »
step 1
mjrii87
« Reply #8 on: March 05, 2014, 09:57:41 PM »
step 2
mjrii87
« Reply #9 on: March 05, 2014, 09:58:04 PM »
step 3
mjrii87
« Reply #10 on: March 05, 2014, 09:58:34 PM »
step 4
mjrii87
« Reply #11 on: March 05, 2014, 09:58:57 PM »
step 5
Philly
« Reply #12 on: March 05, 2014, 10:36:42 PM »
Thanks for the photos mjrii87. That's a really big help as I have not removed the front panels yet.
Great job. Thanks again.
mjrii87
« Reply #13 on: March 05, 2014, 10:39:05 PM »
Glad to be of help!  ;D
mszallen
  • Live to ride
« Reply #14 on: April 04, 2014, 12:45:54 PM »
I'm installing heated grips on the DT and the dealer tells me I have to remove the front fairing.  Are those all the steps required to remove the faring or are there others?  Please advise.
