Number #1 shield SOLD and Number #3 shield is SOLD.
The Number #2 shield is all there but has a crack, to eliminate it from cracking more you will need to drill a round hole and/or take a side drilling dremel and make the crack a little wider as if it was meant to be there and you should not have any issue with the crack further.
I think that part is also covered by your body work.
