Author Topic: restriction problem  (Read 7196 times)
franx93
restriction problem
« on: September 08, 2009, 10:15:11 PM »
hello....on my agility 2008 R16 i put an unrestricted boss, cut violet wire, and put #82 main jet...but it goes only 55 km/h. if i plug half air hole behind the filter it goes 62/63km/h, but some friends go 65km/h plugging nothing. is there any other adjustament to do at the carburator?
thank you for your time :)
« Last Edit: September 09, 2009, 12:11:58 AM by franx93 »
Re: restriction problem
« Reply #1 on: September 09, 2009, 10:21:29 AM »
..i thought the wire was green......hmmm...
..try an 85 jet..you may be running lean...
peace
franx93
« Reply #2 on: September 09, 2009, 10:30:13 AM »
i tried an 86 jet...it runs better but doesn't go 65 km/h...i don't know why...:( the carburator is also clean
« Reply #3 on: September 09, 2009, 10:32:29 AM »
..where did you cut this violet wire??
« Reply #4 on: September 09, 2009, 10:38:51 AM »
...this is where you should cut..
« Reply #5 on: September 09, 2009, 10:43:44 AM »
..my dealer did this..
franx93
« Reply #6 on: September 09, 2009, 11:18:32 AM »
my cdi is not this. is original r16 cdi...and the restriction go out cutting violet wires..
« Reply #7 on: September 09, 2009, 11:49:07 AM »
..this is my original Agility 50 cdi...
..what scooter do you have??
Kenho21
« Reply #8 on: September 09, 2009, 12:19:45 PM »
I adjusted the engine size, lol
Ken
« Reply #9 on: September 09, 2009, 12:20:58 PM »
Ken
 :D ;D :o
franx93
« Reply #10 on: September 09, 2009, 12:30:17 PM »
agility 2008...the problem is not the cdi, i'm sure...so, is there any adjustament to do at the carburator except main jet and needle jet? (#86 main jet and original needle jet.)
« Reply #11 on: September 09, 2009, 12:41:52 PM »
..I bought my 08 Agility 50 new...These pics of the cdi are of STOCK cdi's...
..If you didn't cut as the pics are shown, then you may very well have a cdi problem...
..and no, there are no other carburetor adjustments to be made, that I know of...
..other than a "High flow" air intake filter, that may require some further carb tuning...
.....Anybody else agree with me??
..or have anything else to offer franx??
peace
franx93
« Reply #12 on: September 09, 2009, 12:58:37 PM »
wordslinger mine is an R16 ;) yours is R12...cdi are different ;)
« Reply #13 on: September 09, 2009, 01:22:56 PM »
..ok, yeah..i overlooked that...
..sounds like you have big problems then...
 ;D
« Reply #14 on: September 09, 2009, 04:30:05 PM »
..franx..comparing the specs of the 2008 A50 r12 and the 2008 A50 r16...
..the A50 r12 has 3.5 horsepower..@ 7500rpm (restricted)
..the A50 r16 has 2.4 horsepower..@ 7500rpm (restricted)
..the A50 r12 weighs 92.5 kg (204 lbs)
..the A50 r16 weighs 100 kg (220.5 lbs)
Is this what your scoot looks like?
..trying to educate myself a bit..  ;)
« Last Edit: September 09, 2009, 04:39:19 PM by wordslinger »
