Author Topic: 2009 Kymco 50cc Cdi cut now 5-7 mph faster  (Read 22606 times)
SeanOaloha
« on: November 01, 2009, 11:40:12 AM »
I recently bought this 2009 agility used with about 5,000 miles on it.......Too SLLLLOOOWW!! I read on the net about derestriction and decided to start with just the cdi, now I dont know if there are other things I need to do because I cut the cdi or will my engine be OK with only the cdi box cut. I do know that it was extremely easy and I now I have gotten up to 45 mph with ease!! So I will post a pic of this cut and hope that others have input specifically for the 2009 agility 50!!
MAHALO FOR YOUR ALOHA!!
Re: 2009 Kymco 50cc Cdi cut now 5-7 mph faster
« Reply #1 on: November 01, 2009, 04:08:02 PM »
No worries on the engine> these are NOT saftey, or protection modifications. The restrictions are there solely to comply w/ local speed limitations for the 50cc licenses laws. The difference you found in the cdi de-restrict, is the same as the diff. in the cvt de-restrict (5-7 mph). Good luck w/ the scoot!
SeanOaloha
« Reply #2 on: November 01, 2009, 09:07:35 PM »
I was hoping someone would say that, I feel like the scooter WAS meant to go this fast, so smooth and sooo quiet!!
franx93
« Reply #3 on: November 01, 2009, 11:50:52 PM »
did you do this cut on r16 agility?
SeanOaloha
« Reply #4 on: November 02, 2009, 03:28:15 AM »
I am not sure it is a 2009 kymco 4-stroke 50cc agility, does that tell ya anything?
scootermaven
« Reply #5 on: November 06, 2009, 03:37:01 PM »
Can you post the pic(s) of what you did to the CDI box?  I also have an '09 Agility 50 that probably needs this done.  Thanks!
Happy scootin'! ;D
I may be slower uphill, but I'm quicker at the gas pump!
« Reply #6 on: November 06, 2009, 06:07:48 PM »
...this is a pretty good representation...
click on th pic for a larger view..
scootermaven
« Reply #7 on: November 06, 2009, 08:25:28 PM »
"Wordslinger",
I know I am looking at the CDI unit from your Agility in the photo, but I still don't know what you actually did to modify it.  I am assuming you had to cut into it somehow to cut a wire, right? See the photos below of what my CDI unit (from a 2009 Agility 50) looks like:
Now, exactly what am I supposed to do to modify it?  Does your unit have the same numbers on it as mine, as I notice the color of your plug is a different color?
Thanks!
« Last Edit: November 06, 2009, 08:29:10 PM by scootermaven »
« Reply #8 on: November 06, 2009, 08:40:29 PM »
..the "wire" is inside the casing of the cdi...cut the casing, and you cut the wire...
..use a hacksaw, or a file, and just whack away until it kinda looks like the pic.. :)
..ppl say "DON'T CUT TOO DEEP"..but as you see in the pic below, there's a good margin for error..
..the other pic actually isn't my cdi...mine looks like this...lol..
..I stopped posting this pic when showing examples...
..obvious reasoning..kinda extreme...
« Last Edit: November 06, 2009, 08:53:59 PM by wordslinger »
« Reply #9 on: November 06, 2009, 09:08:25 PM »
..franx, scootermaven's is an r12...
« Reply #10 on: November 06, 2009, 09:09:36 PM »
..you can "fix" that quiet problem with a high-flow air filter..lol..
 ;D
scootermaven
« Reply #11 on: November 06, 2009, 09:23:17 PM »
So, "Wordslinger", see photo below for my questions...
« Reply #12 on: November 06, 2009, 09:25:23 PM »
...i's a very small wire, and you can see it..in real life...
..usually, the blade or file will drag plastic over the copper...makes it kinda hard to see..
« Reply #13 on: November 06, 2009, 09:36:31 PM »
...DON'T DO IT LIKE MINE!!!
..my dealer did that..lol.
« Reply #14 on: November 06, 2009, 09:39:45 PM »
..the wire is maybe 1/8" deep in the casing...right in the "top" edge...
