Author Topic: These the right parts - Dr. Pulley 20x12x14 Sliding Roller Weights  (Read 3476 times)
Budz
Are these the correct ones for my 2012 GT300i?
http://www.amazon.com/gp/product/B00J5LPSIE?&ref_=pd_ybh_20
« Last Edit: July 09, 2015, 11:32:55 PM by Budz »
agilebda
Re: These the right parts - Dr. Pulley 20x12x14 Sliding Roller Weights
« Reply #1 on: July 10, 2015, 01:10:46 AM »
Yes. Correct set of sliders. Enjoy them!
Yellow Jacket
« Reply #2 on: July 10, 2015, 01:51:41 AM »
"right" as in same weight as OEM rollers?
Scooter owned in the past, Honda Aero 125, '87 Elite 150 (2), '87 & '90 250 Elite, Yamaha 200, (2), 400 Majesty, Aprilia  Atlantic 500, Piaggio BV250,SYM HD200,  Kymco Yager GT200
Current ride, Kymco GTi 300
Budz
« Reply #3 on: July 10, 2015, 03:33:41 AM »
"right" as in the correct size and weight to improve acceleration, mid range while keeping top speed at OEM.
Reading this forum, apparently improvements can be; acceleration by 2 seconds and stronger mid range...
mrmike
  • Syuracuse, NY
« Reply #4 on: July 10, 2015, 06:37:15 PM »
Worked great for me! Don't know if any lighter would be any better. The 14's are definitely better than stock IMHO.
Yellow Jacket
« Reply #5 on: August 30, 2015, 01:04:34 AM »
     Finally had a chance to do some testing of DR Pulley sliders. I would like to point out that I have many years of tuning and racing high performance motorcycles. When I make any change I try to test the change to make sure if and how much that change effects performance. One thing I learned long ago is that the "butt crack" dyno is the least accurate method of measuring performance. For scooter testing I have a "secret" test site I use.  Very little traffic, up hill, about 120 yards long. I make 8 full power runs between paint marks on the road, timing each with a stop watch.  In addition, I have a small electronic tach with memory. After each run I record time and max RPM's reached. Throw out the best and worst runs and average the remaining 6. Admittedly not very high tech but for the money it's a pretty good method.
    To start the testing I first did a baseline. My bike, '12 Kymco GTi 300 with 9K miles, completely stock including top case and stock rollers lightened to 13.2 gr. by drilling them out to 3/8 inch. My time average was 8.42 seconds with RPM peak of 6190. With stock 15.5 gr. rollers I have recorded 8.66 time back when the bike only had about 1000 miles on it.
    Next I installed 15 gr. sliders. Normally I only make one change at a time but at this time I did check the air filter and gave it a good cleaning. Not sure how much the cleaning effected the test but am sure it was very little. Time dropped to 8.04 sec. @ 6380 RPM's. This is a very dramatic improvement, enough to convince me to go with DR Slider in any scooter I own. Top speed, using GPS and a two way average, was 84 MPH, exactly the same as before the change.
    With sliders lightened to 14.2 gr. the numbers improved to 7.87 @ 6710 RPM.
    Finally lightened to 13.6 gr. numbers were 7.68 @ 6865 RPM.
    I've not tested top speed but have no reason to think it has changed. Peak torque for this motor is at 6500 RPM and peak HP at 7750. I think you get your best acceleration over a given distance if you can get the RPM's up near the peak HP figure and above the peak torque value. On the GPS top speed test I reached 7888 RPM. At that RPM the bike is past the power peak where power drops off fairly quickly. Meaning that it simply will not go any faster unless something is done to increase HP and the RPM of power peak. It is possible that a slight change in gearing might yield a couple MPH but changing gearing is not an easy task. Also, taller gearing, if possible, would come at a cost in off line performance.
    For anyone interested, the drill to use for various weight sliders is 11/32 = 14.7 gr., 23/64 = 14.2 gr., and 3/8 = 13.6 gr.  Hope you find this useful. My conclusion, I'll keep the 13.6 gr. sliders but will order new 15 gr. ones to install if I undertake a long trip.
« Last Edit: August 30, 2015, 01:14:32 AM by Yellow Jacket »
zevsdad
« Reply #6 on: November 16, 2015, 02:39:26 PM »
Hello! Guys-first before I start-please forgive my noobiness. OK with that out of the way here goes:
Are these sliders the same thing as the weight bearings? I was told by some guys at Kymco that the crunching paper sound I am hearing from my muffler area is caused by worn out weight bearings.
If so and I need to change them out, can anyone provide a very detailed step by step? I was also told to be very careful with this job because I would have to remove the drive belt.
I found this but I dont sproiken du Duetsch
oh and one more thing-I need to replace the plastic grey cover-it got cracked. Where can I purchase that?
thanks in advance for any help
« Last Edit: November 16, 2015, 02:51:08 PM by zevsdad »
« Reply #7 on: November 16, 2015, 04:39:53 PM »
Zevsdad, I am NOT picking on you but I do not recognize the term " weight bearings". Could these shop guys explain what they are?
Replacement parts are ordered from the dealer or some cycle scrap yard like West 60 Cycle Salvage in Neosho, MO who is also a Kymco dealer.
zevsdad
« Reply #8 on: November 16, 2015, 09:59:07 PM »
sorry-scratch 'weight bearing' and make that 'CVT roller weights'
I think what they were talking about is definitely  sliders?
« Reply #9 on: November 17, 2015, 04:55:54 PM »
Rollers or sliders your choice. Recommend you find and fix the noise. OK if caused by damaged, broken or missing rollers. They are on the left side, ya know! Could be something in CVT case that should not be.
zevsdad
« Reply #10 on: November 17, 2015, 06:03:34 PM »
good point! yeah the noise seems like its coming from the right side(muffler) not the left-but then again it just be hard to determine exactly where the noise is coming from. I think what I will do is go ahead and change out the rollers and replavce with Dr P 14g and see if that fixes it.
