My headlight on my Kymco Super 8 dont work right.Sometimes it work for some minuts and then it just turns off for no reason and sometime later it turns on again.
It acts like a loose connection but i dont think it is because i have checked all the connections many times now.
I found that the 7 amp fuse to the "light control box" has melted some of the plastic on the fusebox and the plastic was inbetween the fuse and the fuseholder but i have fixed that and it diddent help.
In this video i have connected the wires just like inside the scooter only the wire that im touching is not connected to the CDI box.
lyskontrolboks2.AVIJust by touching the wire with my finger i can make the light turn on.
I use a T connection from a tv antenne thing because the surface on the little metal box is rough and i can make the light turned on better.
Here i connected a 12 volt low amp transformer instead of the battery and only 1 light bulb.
lyskontrolboks1.AVILook how the light come on in pulses and then turns off.
It diddent work with the transformer and both light bulbs... i things its because the transformer couldent give as much amps as the batteri can.
Now the thing i would like to know is what signal is the "light control box" supposed to get from the CDI box ?
I measured 1,6-2,2 volt on the wire to the CDI box when its in the scooter and the engine is running and the headlight works.
Its as if the wire needs a signal like the pickup (pulser coil) is generating for the lights to stay on... like a ON OFF ON OFF ON OFF... signal.
PS : the box in the video is a "light control box" and not a cdi box eventhough they look the same.
Have a look at :
http://mentos.wep.dk/scooterhjemmeside/elektrisk.html#lys_kontrol_boksPlease give your comment and ideas
