customx22
« on: February 07, 2010, 11:15:23 PM » |
what can i do if i striped my crank shaft?
« Reply #1 on: February 08, 2010, 04:37:35 AM » |
..buy a new one..
« Last Edit: February 08, 2010, 11:04:46 AM by wordslinger »
'08 Agility 50....... $1800.00 52,000 km...60 mph downhill.. '01 People 50.........$500.00 A beastie in th' works..PRICELESS..
« Reply #2 on: February 08, 2010, 08:59:49 AM » |
What exactly is striped? I have run a die over the crank ends in the past w/ very good results.
They have nothing in their whole imperial arsenal that can break the spirit of one Irishman who doesn't want to be broken.
customx22
« Reply #3 on: February 08, 2010, 06:54:34 PM » |
ok i ran the die over with a snap-on die 12mm 1.25 and it worked great.im never using an impact gun on that crank again.i use all hand tools now.
« Reply #4 on: February 08, 2010, 07:42:04 PM » |
The nuts on both ends of the crank are supposed to be "capture" nuts, meaning they have a slight deformity in their shape. Although you cannot thread a new nut on by hand, an impact should not be used. ( as you pointed out). Glad you got it sorted out though. In a pinch if a new nut is not available a little dab of blue lok tite should be used.
« Reply #5 on: February 09, 2010, 10:46:33 AM » |
..i've always been afraid of using impact wrenches on my scoot...i've seen the damage they can do in other applications when not used correctly..
customx22
« Reply #6 on: February 17, 2010, 02:17:30 AM » |
wordslinger how do you torque down you crankshaft nut? what do you use to hold it in place?
« Reply #7 on: February 17, 2010, 04:37:41 AM » |
...I use a pair of vise-clamps...they spread apart just far enough, with the adjusting screw backed out...clamp them aroung the teeth of the flywheel, and just prop them against a piece of 2 X 4 on th floor...use a 1/2" drive 17mm socket and ratchet on the nut...it's all I had handy the first time I ever opened the cvt, but it works ok...and it was FREE!!..
..I'm a maintenance supervisor...I've seen soo much damage done to stuff by impact wrenches used improperly...Don't like the idea of all that pounding force being introduced into my engine either..
customx22
« Reply #8 on: February 17, 2010, 02:09:56 PM » |
do you use a torque wrench to torque down? what do you torque them too?
« Reply #9 on: February 18, 2010, 04:42:36 AM » |
Shaka
« Reply #10 on: February 19, 2010, 04:50:33 PM » |
The manual calls for 5.5-6.5 kgf/m which equals about 40-47 lbs/ft. I use a cordless impact gun on mine. It is relatively weak at a rated 85 lbs/ft. I just use this to re-install the nut. I don't sit there and drive the crap out of it, but I get it on there pretty good! I have never had any problems with the threads even coming close stripping, I did strip one of the nuts trying to get it off the first time though! It was obviously on tighter than that before!
« Reply #11 on: February 20, 2010, 08:09:02 PM » |
ya its ok to use impact to take off but use the old elbow to put back on. you can make tools for this or get theam at your motorcycle shop.
