Author Topic: Changing CDI  (Read 22000 times)
Neko
Changing CDI
« on: March 02, 2010, 08:47:07 PM »
I have been reading through the posts for de-restricting, and am wanting to change the CDI or disable the rev limiter.
But have not seen any like mine.
I have a 2009 Super8 2T.
Can somebody help me out, and tell me exactly what I need to buy or mod.
I hoping the pics I've taken show up!
Many Thanks.   :)
Super 8 2T
Re: Changing CDI
« Reply #1 on: March 02, 2010, 09:59:22 PM »
I can see 6 wires on the harness! How many pinns are there in the cdi? Also it looks like there are 2 green wires in the harness. Is one of them dark green (the other lite green)? I'll look around to see if that is the same type cdi in the zx. Your answers will help.
Neko
Re: Changing CDI
« Reply #2 on: March 02, 2010, 10:27:34 PM »
The CDI has 8 pins (See pic).
One of the wires is Green, the other is Green with a dark stripe.
Super 8 2T
Re: Changing CDI
« Reply #3 on: March 02, 2010, 10:30:11 PM »
Is this a UK bike?
Neko
Re: Changing CDI
« Reply #4 on: March 02, 2010, 10:33:49 PM »
Super 8 2T
alchemy67
Re: Changing CDI
« Reply #5 on: March 05, 2010, 12:06:41 PM »
Hi, you could do what I did and emailed customer services at MASCO, they are the distributors for Kymco in the UK. I asked them which wire to cut on my super8 50 4t and a guy came back 2 days later and told me what to do.  That way the info is straight from the horses mouth so tom speak!   No harrm in asking is there?
regards
Neko
Re: Changing CDI
« Reply #6 on: March 05, 2010, 12:53:33 PM »
Thanks for the info, I have telephoned MASCO, and was told there is no rev limiter, and so it cannot be removed.
There is on the 4T, but not 2T!
Super 8 2T
scootergrisen
    • scootergrisen
Re: Changing CDI
« Reply #7 on: April 01, 2010, 03:48:28 AM »
Yeah i seems like the CDI are not retricted on you model.
Heres my CDI from my Kymco Super 8, 4 stroke 50 ccm with the 2 ekstra wires.
Re: Changing CDI
« Reply #8 on: May 20, 2010, 01:07:21 AM »
regards
..what did they say to do??
Re: Changing CDI
« Reply #9 on: May 20, 2010, 02:47:14 PM »
  The Uk bikes are done at the air box/ carb main jet/ var bushing/ exhaust pipe washer. You need to remove the washer in the exhaust header, change the variator boss, remove the restriction in the air box, and go up 2 sizes on the main jet. That will get you rocking.
Re: Changing CDI
« Reply #10 on: May 20, 2010, 02:49:29 PM »
  I just posted this in the thread you referred to. Chase down these few bits, and you will be good to go.
jbcinzio
  • I was the second gunman on the grassy knoll....
Re: Changing CDI
« Reply #11 on: June 12, 2010, 03:01:07 PM »
regards
Which wire do we cut for the 50cc 4T?
This message was posted using 100% recycled electrons.
Re: Changing CDI
« Reply #12 on: June 12, 2010, 03:05:48 PM »
Either one of the 2 pink wires.
Neko
Re: Changing CDI
« Reply #13 on: June 27, 2010, 10:21:20 AM »
Zombie,
 Please can you point me in the right direction to find this. It was a while ago, and I've been on vacation.
Cheers,
Neko
Super 8 2T
Re: Changing CDI
« Reply #14 on: June 29, 2010, 02:52:37 AM »
  Hey Neko, This is the post. Inside your variator there is a sleeve that everything rides on. At one end of the sleeve (boss) there is a shoulder that is easy to have machined off. Go to http://www.stadiumyamaha.com/pages/parts/viewbybrand/default.aspx  and look up your scoot. Look at the cvt picts, and the boss is # 22105 in the pict. That is the MAIN restriction on your scoot. The shoulder has to be cut down to the same diameter as the rest it. Next... Open your air box, and right in front of the carb. is a square plug with a hole in the middle for the air to flow thru. Just pull out that plug, and toss it away. after that you can get a bigger Mian jet from your dealer. It will be 2 sizes bigger than the one in there now. The last bit is in the exhaust. There is a washer welded into the engine side end of the pipe. Use a dremmel tool to cut it out, and you are done. You will see 45 mph.
