Author Topic: Malossi multivar instalation  (Read 5484 times)
marioG
« on: May 22, 2010, 05:40:53 PM »
Guys, need help...
Got M5111545 and its got one spacer....where does it go?
Yeah, instructions are crap...bloody malossi....
I think the spacer goes at the and before kick start thingy?
« Last Edit: May 22, 2010, 09:05:40 PM by marioG »
FUBAR is an acronym that commonly means "f***ed up beyond all recognition/any repair".
Re: Malossi multivar instalation
« Reply #1 on: May 22, 2010, 09:13:56 PM »
...can you post a pic of it??
marioG
« Reply #2 on: May 22, 2010, 09:25:39 PM »
http://www.malossi.com/Archivio_Files/MONTAGGIO/73%203863.pdf
its called Malossi adaptor.....
Page 9 at bottom...
« Reply #3 on: May 22, 2010, 09:39:34 PM »
...the drawing depicts the order in which each component should be installed...
..does it not fit your scoot's output shaft??
« Last Edit: May 22, 2010, 09:52:59 PM by wordslinger »
marioG
« Reply #4 on: May 22, 2010, 09:55:31 PM »
Yes it does.
But i have another order....
1)  vent
2)  kickstart
2)  orig washer
3)  nut
Where to put it?
Between 1 and 2?
« Reply #5 on: May 22, 2010, 10:04:19 PM »
...the malossi should "fit" exactly as your original variator...
..the variator you bought will fit other makes of scoots also...
..if the nut will tighten everything against the washer, and variator assembly, with some threads still protruding out past the nut, then you don't need it on your scoot..
..everything MUST be installed in the order that the pic shows...you may or may not need the adapter...i can't say without seeing how you have it all on your scoot...
..maybe somebody else here has installed that variator on the A125...
peace
« Last Edit: May 22, 2010, 10:24:39 PM by wordslinger »
marioG
« Reply #6 on: May 23, 2010, 04:42:28 AM »
Will take pic today...
Hub is just shorter for the size of 5mm (size of extra washer)...
Its original for Kymco People, Movie and Agility...dont know why Malossi would put it in kit if i dont need it...
Only problem is Why this model is not in manual, so all pic there include that on page 9 at the bottom are pretty different from real Kymco...
Blame on them coz is that they change rollers from 10,5 to 11,5g and they didnt go extra mile to explane where to put fck spacer...
And this stupidity can cause much damage to shaft...
marioG
« Reply #7 on: May 23, 2010, 08:40:00 AM »
Tnx wordslinger;
on far left/right is malossi, and inner side is serial....
Ive put washer/spacer/adapter on kick and then original washer...seems to me that this is wright...
Now 11.5g roller on 125cc is a bit low (50cc sound)....need something like 13g....
Scoot is to 80kph like rocket and then slows down....need to test it more...
« Last Edit: May 23, 2010, 08:46:08 AM by marioG »
marioG
« Reply #8 on: May 24, 2010, 09:58:09 PM »
Does anyone install 13g to multivar?
ramp looks ok like standard....
« Reply #9 on: May 24, 2010, 10:03:52 PM »
...mario, is there a difference in the moving pulley's ramps??
..what i am talking about, is th "tracks" that the rollers ride in...
.. are the arcs of the tracks the same from the center to the outter edges?
..just wondering...  ;D
marioG
« Reply #10 on: June 19, 2010, 12:32:11 PM »
Solved this, malossi spacer come before multivar....
changed 11,5g rollers to 13g...
also change belt to Dayco 800x30....no more bouncy start...
paali10
« Reply #11 on: June 13, 2012, 10:48:00 PM »
I know this topic is old, but I have the same problem with my Agility 50.. What do you mean the spacer before multvar? Isnt that the name of the variator?
« Reply #12 on: June 14, 2012, 12:02:38 AM »
..paali, the 50cc does not use the black ring, that comes with the malossi multivar variator kit..
marioG
« Reply #13 on: June 14, 2012, 05:09:54 AM »
http://www.malossistore.it/Prodotto.aspx?type=M&MM=MO/KYAG5016&C=5113790
think thats not spacer, its just gear/speed limitator for 50cc..... u dont need that?
multivar has some kind of problem with materials used in some scooters so that washer/spaser comes before multivar.... to protect!
