Author Topic: Speedometer not working and ABS light on due to faulty wiring (fix)  (Read 4676 times)
mousejunks
Today I got on my bike for a ride and noticed that the speedometer wasn't working (0km/h) and the red ABS warning light was on. I took it back to the garage and inspected the bike. The wheel speed sensor near the front brake caliper was fine, but when I followed the wiring up into the bike, one of the two wires was broken clean from the crimped bullet connectors. After soldering the wire back to the connector and covering it, the problem was fixed immediately.
There is an obviously a design fault with the wheel speed sensor wiring. The first 50cm of wiring from the sensor is quite strong since it is double insulated. However, the two wires become exposed and are connected to the wiring loom with flimsy bullet connectors. These two wires move back and forth every time you turn the handlebars, causing them to break from fatigue.
'09 Kymco Espresso 150i
'17 Kymco Downtown 350i ABS
Re: Speedometer not working and ABS light on due to faulty wiring (fix)
« Reply #1 on: October 15, 2016, 01:52:45 PM »
Something to definitely check for all DT300i. This fixed the ABS light, too?
TANWare
« Reply #2 on: October 15, 2016, 05:44:01 PM »
That would if that wire was a shared ground.
mousejunks
« Reply #3 on: October 15, 2016, 11:06:05 PM »
Yes, the ABS warning light turned off too.
I have a photo of the wires. The red wire has snapped off the connector and the black wire is exposed due to broken insulation.
mousejunks
« Reply #4 on: October 30, 2016, 10:29:36 AM »
Just an update on the fix. I cut off the crappy bullet connecters and soldered the wires with heatshrink afterwards for a waterproof, permanent fix.
Just for future reference, the red wire from the harness connects to the white wire from the sensor. Strangley enough, two of the wires were made from aluminium and the other two were copper.
« Reply #5 on: October 30, 2016, 11:14:49 AM »
Nice job, mouse!
