Author Topic: MXU 450 new tires and valve check  (Read 1742 times)
Bratman2
« on: December 04, 2016, 04:04:01 PM »
Rolled past 250 miles the other day. Decided I would do an oil change (Mobil 1 0w-40) and check the valves. Valve check was super easy. Remove seat, remove black plastic side panels, remove gas cap and plastic tank cover. Then unplug wire harness and undo screw clamp on fuel hose. Remove one allen head bolt and tank slides right out. Cover tray between fuel tank bottom and top of engine pops right out. Remove plug on left hand side of motor to set piston on top dead center. I carefully used a bamboo stick to confirm top dead center. {Piston all the way up and rocker arms with free play. I used 0w-40 Mobil because I had some, use it in my wife's turbo Subaru. Valves were with in specs so no adjustment was necessary. Also pulled and cleaned the air filter. For me it seemed pretty easy to undo the clamps on the duct for and aft of the filter. Pull the housing out of the wheel well and remove the filter disconnected from the atv. I have heard some on the Arctic Cat forum pure cuss this filter housing access but seemed fairly easy for me the way I did it.
« Last Edit: December 04, 2016, 04:17:06 PM by Bratman2 »
2019 UXV 700i LE Hunter
2014 MXU 450i
2004 Mongoose 90 (grandson's)
2010 Grizzly 450
Bratman2
Re: MXU 450 new tires and valve check
« Reply #1 on: December 04, 2016, 04:13:12 PM »
Oops, forgot the tires! Carlisle ACT 25x8R-12 radials front and Carlisle Badlands XTR 255x65R-12 rear. I wanted to use the ACT tires all the way around. The rear ACT 25 is an 11" wide rear tire (25x11R-12) and is suppose to use an inch wider rim than I have. Kind of sucks but I like what I have pretty good! Included one more picture of what I found while adjusting my valves. The duct for the CVT cooling vent not properly attached. May pay to check your ATV out pretty good. I remember reading about a new Can-Am mudpro that the duct from the throttle bodies had loose clamps on. Allowed the engine to flood with water crossing a stream.
2014 MXU 450i
2010 Grizzly 450
