Author Topic: 2008 Agility 125 no spark  (Read 3017 times)
Jymco
« on: March 10, 2018, 10:22:14 PM »
Any help for me on this scooter? It's my daughters and she needs it for school. It crapped out yesterday and the first thing I did was gave it a shot of ether and got nothing. So I pulled the plug to check for spark. Nothing. I put a new plug just to be sure and nothing. I checked the 2 fuses that are by the battery, but they seem to be good.
tortoise
Re: 2008 Agility 125 no spark
« Reply #1 on: March 11, 2018, 03:38:36 AM »
Jymco
« Reply #2 on: March 11, 2018, 02:11:51 PM »
Excellent. Thank you. I'll check that out.  :)
« Reply #3 on: March 11, 2018, 08:04:40 PM »
Run/stop switch in run position?
Jymco
« Reply #4 on: March 13, 2018, 02:25:10 AM »
No. It's kinda worn, but, I tried it in both positions.
Jymco
« Reply #5 on: March 15, 2018, 01:29:39 AM »
Ok I checked out the numbers and here is what I got.
Key off:
Blue/yellow 1.3 ohms
yellow .7 ohms
white .8 ohms
Key on:
Blue/yellow 104.4 ohms
Yellow 18.8 ohms
White 17.3 ohms
Turning the engine over:
Blue yellow Zero ohms (or wasn't enough to register on my meter) .017 volts
Yellow 0 ohms 0.8 volts
White 0 ohms 0.8 volts
I don't know what all that means, but it looks like the Y and W don't have the volts when cranking the engine. I hope someone can help.  :D
Jymco
« Reply #6 on: March 15, 2018, 01:30:44 AM »
Deficient trigger/pickup/pulsar coil?
Key off:
yellow .7 ohms
white .8 ohms
Key on:
Yellow 18.8 ohms
White 17.3 ohms
« Reply #7 on: March 24, 2018, 03:26:07 PM »
Can you try another known good 12v battery? (Not the car battery with car running!!)
Unthread spark plug cap, trim 1/4" off wire end, screw cap back on.
Jymco
« Reply #8 on: March 24, 2018, 05:38:38 PM »
I did that to the plug wire already on advice from a friend. The battery is fairly new and still has a charge after charging it at least 2 weeks ago. But, I can try another, but it seems not necessary.
Thank you!
« Reply #9 on: March 25, 2018, 12:33:41 AM »
 You did well on the plug wire. The battery, however, needs some clarification. What does holding a charge mean in actual numbers?
Jymco
« Reply #10 on: March 25, 2018, 02:20:22 PM »
It's been holding a charge meaning that I can at anytime crank the engine over. It sounds like it's cranking at a normal speed. But, maybe later today I'll check it with a volt meter. Should I check it not cranking and while cranking?
Thank you C.B
« Reply #11 on: March 25, 2018, 08:56:08 PM »
Yes, both ways. That will give a no load and full load voltages which will be helpful.
Jymco
« Reply #12 on: March 25, 2018, 11:37:02 PM »
Well, I went out and checked the voltage on the battery with the key off and it was 12.5 volts. So, I hit the starter.....and the damn thing started!  :o
Idk if when I was pulling on the wires that come out of the engine that something was loose or maybe it was the plug wire and I didn't check well enough after I cut it. Damned if I know. I took it for a ride and it runs fine.
Thanks for you help!  ;D
