esellie
Newbie
« on: July 28, 2010, 03:32:58 PM » |
Does a person gain anything by buying a de-restricted CDI box or is this just for the people that don't dare cut in wire in their existing CDI box? I'm just wondering if there are any additional benefits.
art
« Reply #1 on: July 28, 2010, 03:40:07 PM » |
Unless doing stage 3 mods the only benifit I see is for the guy's you buy it from
« Last Edit: July 28, 2010, 05:56:39 PM by art »
Kymco peoples too many  I'm not an expert just a full time hobbiest.
« Reply #2 on: July 28, 2010, 03:45:33 PM » |
..you can order, from Sutai, a "programmed" cdi that will manipulate your engines performance at certain revs...
..however, for most ppl, if you CAN de-restrict your cdi, by whatever method, then it's a FREE mod well worth the time it takes to learn how it's done..
..a "race" cdi is only better, if you also upgrade all the other ignition components...
..just my opinion...
'08 Agility 50....... $1800.00 52,000 km...60 mph downhill.. '01 People 50.........$500.00 A beastie in th' works..PRICELESS..
esellie
Newbie
« Reply #3 on: July 28, 2010, 04:46:10 PM » |
Mine is a 2009 model and has the following wire colors: Green, blue/yellow, black/yellow, and black. I have noticed that in some of the pictures of the CDI boxes that some appear to be transparent on the top that you cut into so you can see what you are doing. My box happens to be solid black so you can't see what you are doing until you cut into it. Is it safe to gently cut into it with a hack saw or razor blade until the copper wire becomes visible and cut through it. Should I still looking for the same brown copper wire to cut through that was described in a previous forum? Thanks!
« Reply #4 on: July 28, 2010, 05:02:05 PM » |
..you want to notch it just like in these pics...
« Reply #5 on: July 28, 2010, 05:05:56 PM » |
...don't be alarmed if you don't see the wire...
..sometimes, the tool will drag plastic back over the copper, making it hard to see...
..this is a pic of my cdi, that was ground off by my dealer...
..as you can see, there is nothing you could damage by cutting a small notch, as shown in the previous post..
« Last Edit: July 28, 2010, 05:25:03 PM by wordslinger »
« Reply #6 on: July 28, 2010, 05:17:30 PM » |
..you can further see that my cdi has the same color wires as yours... ..the red wire is not connected to the cdi...  peace
esellie
Newbie
« Reply #7 on: July 28, 2010, 05:54:44 PM » |
Thanks wordslinger! I made the change and got an extra 5 mph out of it. I weigh about 235 pounds and previously 30 mph was my maximum speed. I can now get up to 35 mph which helps a lot. I noticed that my speedometer on the scooter shows about 5 mph higher than it really is. When the scooter says I'm doing 40 mph my GPS I took with me says 35 mph. I think Kymco wants me to think I'm going faster than I really am. Would anyone recommend me working on the boss drive for the next modification or the carberator? I would really like to be able to get it up to 45 mph. Thanks!
« Reply #8 on: July 28, 2010, 05:59:17 PM » |
...gotta do the boss next!!!!!
..that'll get you to 45..and maybe even more downhills...
.i weigh around 225 m'self...and yeah, most scoot speedos are a bit optimistic..
..with mine, the offset get less as speed increases...
« Reply #9 on: July 28, 2010, 06:28:34 PM » |
..do you know if there are any numbers printed on the top of your carburetor?
art
« Reply #10 on: July 28, 2010, 06:34:47 PM » |
Depending on the carb it might be here
« Reply #11 on: July 28, 2010, 06:38:20 PM » |
...4-stroke carb looks nthing like that...
esellie
Newbie
« Reply #12 on: July 28, 2010, 07:40:59 PM » |
wordslinger - The numbers on the top of my carb are: CK50QT-5
« Reply #13 on: July 28, 2010, 07:43:56 PM » |
...dude, you have a little beastie in the making....
..that scoot is the same build as mine..
esellie
Newbie
« Reply #14 on: July 28, 2010, 08:08:45 PM » |
If I get it up to 50 mph I'm heading for Sturgis!!
