Author Topic: 2015 agility 50 starts than dies  (Read 977 times)
Tiro
« on: April 15, 2019, 01:33:20 AM »
Bought a 2015 agility with 300km it's been sitting for 2 years.
Changed the fuel it starts but it dies after 3-4 seconds. The headlight turns on only after it starts and goes off when the bike dies.
eamartin
Re: 2015 agility 50 starts than dies
« Reply #1 on: April 15, 2019, 02:21:09 AM »
1-if it's carbureted, it likely has a clogged slow jet (from sitting for 2 years with ethanol-laced fuel) preventing it from idling.
2-that headlight beam is run off AC current so it only comes on when the alternator is turning (i.e. when the motor is spinning the alternator fast enough to generate AC current).
Remove the carb, remove and clean the jet, making sure you can see light through it when you are done.  The headlight is not a problem.
Tiro
« Reply #2 on: April 24, 2019, 10:18:13 PM »
the jets were all green and blocked. Ended up buying a new carb and all is good.
eamartin
« Reply #3 on: April 24, 2019, 10:32:43 PM »
Thanks for the follow-up.  I was wondering how it turned out.
Viper254
  • Moped Pirate
« Reply #4 on: April 25, 2019, 09:06:59 AM »
Everyone likes a happy ending to a scooter story.
Rides;
Suzuki GW250 Inazuma (2016)
Honda C70C (red, 1983)
woyciesjes
« Reply #5 on: May 05, 2019, 02:28:09 PM »
Which carb did you get?
2014 Agility 50 4T
Still stock after all these years...
Except for a 19mm carb now.
jesseg010
« Reply #6 on: May 05, 2019, 11:15:53 PM »
buy a new car. you'll be glad you did.
they're relatively cheap
