Author Topic: Naraku Drive Belt  (Read 9033 times)
rliburd2002
Naraku Drive Belt
« on: October 06, 2010, 12:31:35 PM »
I would stay well away from these. I fitted one in June and it only lasted 2 months!!
omfgdotcodotuk
  • fookin quick gilera ice 50/70cc malossified ish
Re: Naraku Drive Belt
« Reply #1 on: October 06, 2010, 07:34:38 PM »
try a doppler,polini or mallosi kevlar they wont let you down ;)
Never ride faster than your guardian angel can fly ;)
sidthesloth
  • Kymco ZX50
« Reply #2 on: October 06, 2010, 07:39:08 PM »
I believe Malossi are good for parts, but their belts are short lived, as far as I have seen, if not going stock, Gates or Dayco are up with the best.
omfgdotcodotuk
« Reply #3 on: October 06, 2010, 08:18:15 PM »
need one for the new kid on the block ;D got a lil slippage going on with the 70 the belt is boned,if you leather it from a standing start i get like a turbo dump valve let off noise from the cvt area so i know thats the prob,yet ride a couple of miles and do the same thing and it stands on the back wheel,kymmmmmmmm come back,lol,no only messin love my ice ;)
sidthesloth
  • Kymco ZX50
« Reply #4 on: October 06, 2010, 08:30:41 PM »
Apparently, Malossi belts are soft, warm them up and they grip, but, trade off is short life. Good for racing, race-replace.
omfgdotcodotuk
« Reply #5 on: October 06, 2010, 11:46:39 PM »
Apparently, Malossi belts are soft.thats the only problem with this set up HIGH FRIKIN MAINTAINCE!!! lol,but again no dis to kymco as you cant have the best of both worlds,as i said in other posts 4t aint for me,unless is starts around 500cc plus,and then i wouldnt have a clue how to fix the engine lol,2t different story ;D ps sid i recon that would explain the avalance of dust that fell out the cvt cover on recent inpection then  ;)
« Reply #6 on: October 07, 2010, 09:57:48 PM »
...i've had good luck with standard Gates "Powerlink" belts...
..had two bad experiences with Kevlar belts..but i was experimenting with belt sizes then...
..kevlar belts make one helluva mess when they pop...
omfgdotcodotuk
« Reply #7 on: October 07, 2010, 11:20:35 PM »
come on slinger more info please,what happens bud? :o
« Reply #8 on: October 07, 2010, 11:24:22 PM »
...you get small chunks of rubber left in your housing and the rest turns to a cottony puffy substance that fills every cubic centimeter of open area within your cvt...
..even gets in between the coils of your fly clutch springs..
..requires a TOTAL disassembly of ALL your cvt components to get it all cleared out....
omfgdotcodotuk
« Reply #9 on: October 07, 2010, 11:30:56 PM »
Goodbye frikin kevlar :o
Ok the results of a none kevlar belt snapping would be?,sorry aint ever had this happen excuse my ignorace :-[
« Last Edit: October 07, 2010, 11:35:45 PM by omfgdotcodotuk »
« Reply #10 on: October 08, 2010, 12:01:59 AM »
...not all belt "sizes" work the best with a particular set-up...
..i'm really liking the gates 729-17.7-28 powerlink belt in my a50...
..it is slightly longer than the oem bando.....
..and i'm kinda itching to run one in my ppl 50...which was the scoot that i was experimenting with belt sizes...
..both "should" run the same belt...but the 2-stroke puts a greater load on the belt...initially, anyway...
« Last Edit: October 08, 2010, 12:11:09 AM by wordslinger »
omfgdotcodotuk
« Reply #11 on: October 08, 2010, 12:18:32 AM »
mmmmmmmm,i need a lil belt research on the offending item ie my scoot lol ;)
« Reply #12 on: October 08, 2010, 12:21:35 AM »
...itsa balance...
..but run what you gots dude!!
..sounds like its screamin'!!
omfgdotcodotuk
« Reply #13 on: October 08, 2010, 12:32:36 AM »
needs a little lower ratio too much set off power,im feeling that one :)
« Reply #14 on: October 08, 2010, 12:34:22 AM »
...a longer belt would take away from the ...take-off..... as well as increase top speed...
..if you can balance it....
