Author Topic: Checking oil - screw cap in or place in position - Kymco People 150  (Read 8308 times)
Lammy1000
I can't find this info.  Appreciate any help.
This has been a great bike.  It is my wife's, but I steal it often.
macs
  • Breakin them in right!
Re: Checking oil - screw cap in or place in position - Kymco People 150
« Reply #1 on: April 15, 2011, 01:33:54 AM »
Level ground and not screwed in. This will be the same of every motorcycle/ atv after 1968 unlEss they have a site glass.
2011 Kymco UXV
2008 Polaris Outlaw 525 IRS
2000 Polaris Sportsman 500
2007 Arctic Cat 700 LE
1987 Honda 200x
1983 Honda 250r
Tricky Dicks Cagiva 200
MrKymco
« Reply #2 on: April 15, 2011, 01:42:12 AM »
i have an Agility 125. my dealer says screwed in and he has been selling Kymco since they were in the country. the correct oil level measured would seem to bear this out
also a neighbor of mines Genuine Buddy 150? screwed in
scoots!
macs
« Reply #3 on: April 15, 2011, 01:48:46 AM »
Wow, could be wrong. Everything from sisxsises to lawnmowers have been this way. What does the manual say?
2011 Kymco UXV
1987 Honda 200x
1983 Honda 250r
macs
« Reply #4 on: April 15, 2011, 02:22:35 AM »
I have looked into 2 service manuals and one repair message. Non of them say
I also looked at it through quarts: size: angle etc etc and I dont think I would make any difference.
2011 Kymco UXV
1987 Honda 200x
1983 Honda 250r
TechGuy
« Reply #5 on: April 15, 2011, 03:18:02 AM »
I looked in my owners Manual and it doesn't say in or out. I know on Vespas, it fully screwed in (as it is discussed to death).
spr0k3t
« Reply #6 on: April 17, 2011, 03:42:48 PM »
Whenever I check my oil levels, it's always screwed in.  Generally I like to make sure the engine is a little warm prior to checking though.  Doing the initial prep on tclock is usually enough time for the engine oil to warm up.
juice
Hoolander2
« Reply #8 on: April 17, 2011, 04:17:42 PM »
From my Xciting 500 owner's manual:
Engine oil level check
(see page 67)
NOTE:
Check the engine oil level each day before riding the scooter.
The level must be maintained between the upper (1) and lower level (2) marks on the oil filler
cap/dipstick.
1. Start the engine and let it idle for a few minutes. Make sure the red low oil pressure indicator
goes off. If the light remains on, stop the engine immediately.
2. Stop the engine and put the scooter on its center stand on level ground.
3. After a few minutes, remove the oil filler cap/dipstick, wipe it clean, and reinsert the oil filler
cap/dipstick without screwing it in. Remove the oil filler cap/dipstick. The oil level should be
between the upper and lower marks on the oil filler cap/dipstick.
4. If required, add the specified oil up to the
upper level mark. Do not overfill.
5. Reinstall the oil filler cap/dipstick. Check for oil leaks.
old mod
« Reply #9 on: April 17, 2011, 04:20:19 PM »
Kymco owners manual says, NOT screwed in :o
Calothrix
« Reply #10 on: April 18, 2011, 12:45:36 AM »
On my 2005 P150, I have always screwed the dipstick all the way in to check the oil level and it appears to read correctly when I add the 0.81 L of oil when changing it.  In my manual it says after you have added oil, to screw the dipstick all the way in, run the bike to warm it up, let it sit for 20 to 30 seconds, then check the oil level.
Chi8
« Reply #11 on: April 19, 2011, 01:18:06 AM »
Super 8 150 manual says not screwed in. Read your manual people!
ts1
« Reply #12 on: April 19, 2011, 05:32:54 AM »
Right, don't screw it in for the oil level check.
Same with Yamaha Teos, MBK Doodo, Piaggio MP3, ...
I don't think any manufacturer would ask for the more complicated way of additional screwing in/out.
sidthesloth
  • Kymco ZX50
re: looking for help, please! having bogging issues with zx50
« Reply #13 on: April 19, 2011, 09:55:30 PM »
Suzuki GS500, not screwed in, to make it worse, it is to be on level ground, not on the side stand, obviously, but also not on main stand either.
