I was bored today so I took my Like apart and took some pics of the restrictor, and how to remove it.
After taking the air box lid off and remove the inlet accordian, here is what you see;
![](http://i8.photobucket.com/albums/a11/91CavGT/KymcoLike200i026_zps733007b1.jpg)
So take the wrench in the tool kit and stick it into the air inlet like this;
![](http://i8.photobucket.com/albums/a11/91CavGT/KymcoLike200i027_zps54f34237.jpg)
After inserting the wrench, then turn it sideways like this;
![](http://i8.photobucket.com/albums/a11/91CavGT/KymcoLike200i028_zpsdfd8ea92.jpg)
Then grab ahold of both the air box lid with one hand and the wrench with the other hand and pull the wrench out like this;
![](http://i8.photobucket.com/albums/a11/91CavGT/KymcoLike200i029_zps36793171.jpg)
As you can see, the insert will come out, but it won't be easy. Once the insert is out, now you can compare the 2 openings and determine for yourself if doing this is worth it or not. Here is the side by side picture for comparison;
![](http://i8.photobucket.com/albums/a11/91CavGT/KymcoLike200i030_zps5ef3c8ff.jpg)
If there has been a loss in low end power, it is not noticeable to me.
