Yours has fuel injection, so you should be fine. I think my carbs have a problem, because after replacing the spark plugs, air filter, fuel filter & petcock, tank breather canister, draining and cleaning the tank, lubing the gas cap mechanism, and putting 3.7 gallons of fresh (non ethanol) gasoline with sea foam in it, the problem reared its ugly head while test riding today. At 25 miles into the ride, the engine started losing power, to the point where I could pull in the clutch and the engine would simply die, even at WOT. Popping out the clutch (at about 30 mph) would re-start the engine. Did this a few times on a rural road for about a half mile, until the engine came back to full power, inexplicably. Rode fine for another 25 miles back to my driveway. Maybe just a temporary clog in one of the carb jets? If anything is clogging the jets, it's not coming from the tank; maybe the old rubber fuel lines are deteriorating inside and little bits are breaking off? Maybe the stealership simply sprayed carb cleaner on the outside of my carbs and charged me $325.00 back in July? Other than the brief problem in the middle of my ride, everything else was great. We'll see if that happens again next ride.
