Author Topic: my gy6 swap frist big ride.  (Read 3944 times)
« on: September 02, 2013, 10:43:09 PM »
took the scoot out for a 120 mile ride last night did realy good I was keeping up with the 125 scoots realy good. Got behind a few times but cought right back up fast ounce I hit the streight aways.   ( man I got a sore back after that ride.)
Bubba
  • 2012 Agility 50. 72cc Big Bore Kit,
Re: my gy6 swap frist big ride.
« Reply #1 on: September 06, 2013, 03:33:05 AM »
What did you swap with? I was thinking of doing a Gy6 swap also and looking to stretch haha
« Reply #2 on: September 07, 2013, 01:21:06 AM »
I put a gy6 50 qmb same thing on a agilty 50 frame. its a wildfire motor.just had to switch out the stator so I could use the kymco wire harnes. tops out on the streights about 45 to 48 .with lighter rollers I could get there fast .But I like it the way it is.
Bubba
« Reply #3 on: September 11, 2013, 04:08:15 AM »
Sounds pretty fancy if I dont end up selling my Scoot im gonna swap a 125 or 150 engine into it
Resolve
« Reply #4 on: September 12, 2013, 08:53:51 PM »
^^^ that was my thought at first get bigger 125 to put on but heard the mounts are different.  Basically by the time you get the engine and redo mounts and get it on you could go buy a new Agility 125 and have same thing with less hassle.
« Reply #5 on: September 13, 2013, 01:31:44 AM »
I was told the 125 and the 50 is the same frame just a bigger motor. And buying just a new motor for a scoot is lot cheaper then buying a new scoot. If the frame rollers why not use it.
Resolve
« Reply #6 on: September 13, 2013, 02:35:43 PM »
I am not saying you couldn't make it work but the frames are slightly different as well as the mounts on the engines.
these are from kymcopartsonline.com
Agility 50 mount bushing 11102
Agility 125 mount bushing 11102
Agility 50 – Body Frame – 50100-LDC8-E10
Agility 125 – Body Frame – 50100-LDF7-M30
Bubba
« Reply #7 on: September 13, 2013, 09:27:59 PM »
Honestly the most trouble im having is finding a kymco 125 engine its a pain. Also im not sure if the Gy6 125 long case engines will even fit..
« Reply #8 on: September 13, 2013, 11:31:33 PM »
O hell thats a easy fix just need to get bigger bushings. or make your own from another scoot.
just make sure they line up good and tight. Better yet find some spacers. Or if ya wana stretch like 6 to 8 inchs make up a mound that will go down to the size you need.
