Author Topic: Adjusting the Valves  (Read 1552 times)
loganhes
« on: September 03, 2013, 05:44:12 PM »
Hello All,
Over the weekend I decided to check the valve clearance on my scoot. It turns out that they needed to be adjusted so I readjusted them to the suggested .004". I put everything back together and started her up and now the valves are tapping slightly. My question is, is this alright that they are tapping or should I take everything apart and tighten up the clearance even more? or will this tapping go away after riding the scoot for a bit? Is it hurting anything when it is making a tapping noise? Any suggestions are appreciated.
--Jim
150cc Kymco Super 8
Re: Adjusting the Valves
« Reply #1 on: September 04, 2013, 02:12:08 AM »
A little tapping is better...just a little.... no tapping at all might be too tight and will lead to damage...
scooterman11
« Reply #2 on: September 05, 2013, 05:01:47 PM »
I took my valve cover off and I could see no extreme play am I good
scooterman11
« Reply #3 on: September 05, 2013, 05:01:56 PM »
