Author Topic: Strange behavior after refueling  (Read 1298 times)
ddrg
« on: September 04, 2013, 02:50:31 AM »
I have a 2010 Yager with 8000+ miles on it.  When ever I refuel it: 1) there is some kind of suction holding the fuel cap closed when I release the catch, and 2) it will stop if I don't hold the gas on within about the first 30 minutes of steady operation.  Is there a fuel filter that needs replacing?  Any others experienced this problem?
Thanks...  Duncan
Re: Strange behavior after refueling
« Reply #1 on: September 04, 2013, 04:57:05 PM »
  I would go to the dealer and try a new gas cap,.
« Reply #2 on: September 20, 2013, 09:05:56 PM »
The cap is vented thru the carbon cannister in the rear of the scoot. The vent is switched on and off by a valve, left side under the footboard, out board of the frame rail (whew!). No vent if this valve sticks. I removed this valve when I had the Yager and coupled the line directly to the cannister. I also capped the vacuum source on the intake manifold. Got rid of the problem.
