Author Topic: gy6 swap all done.  (Read 2316 times)
gy6 swap all done.
« on: September 04, 2013, 03:58:32 PM »
Im all done with the scoot may add a few small things.
she rides good.
gy6 wildfire motor
20 mm carb with a 85 jet drilled out just a little larger.
6 gram rollers
open air filter.
10 inch tire on back.
and a the kymco stator.and wireing harnes.
gets top speed of 45 to 48 easy 30 to 35 up hills.
« Last Edit: September 04, 2013, 04:00:14 PM by blue »
Re: gy6 swap all done.
« Reply #1 on: September 04, 2013, 04:02:08 PM »
Had to add a little ornge to be seen at night.
« Reply #2 on: September 04, 2013, 04:03:59 PM »
the 10 inch tire on back realy makes for good speed.
« Last Edit: May 04, 2014, 02:58:36 AM by blue »
tsnow8
« Reply #3 on: May 03, 2014, 01:00:37 AM »
Nice work! I think this is a great option for a replacement engine.
  I'm relly hopeing you can help me. I own a 2007 kymco agility 125. I just swapped my kymco engine with a new GY6 engine! Everything is working great, except, now my headlight and dash lights do not work. Can you please tell me what might be causing this? A local scooter shop told me to swop the stator on the gy6 engine with the stator on the old kymco engine and it should work, because one part of the stator powers the headlight only!  There is no power coming to the headlight now.
  I have 2007 Kymco agility 125. I just swapped the engine for a Chinese GY6 short case. I had to purchase a gy6 rear wheel, and a gy6 exhaust, because the kymco parts did not fit anymore. All I have left is this light issue and I'm back on the road. Any advise or thoughts would be greatly appreciated.
Thanks.
« Reply #4 on: May 03, 2014, 01:06:46 AM »
Someone else just posted the same thing... Swap the stators, and you will be good to go.
« Reply #6 on: May 03, 2014, 01:21:00 AM »
12 beers, and you will never find it. (so I am told ;))
« Reply #7 on: May 04, 2014, 03:03:12 AM »
Ya you will need to swap the stator.
« Reply #8 on: May 04, 2014, 03:05:29 AM »
O ya if ya dont swap the stator you will end up blowing the cdi and the elec relays and you dont eant that.
« Reply #9 on: May 04, 2014, 03:08:41 AM »
Experience! There is no substitute! ;)
tsnow8
« Reply #10 on: May 05, 2014, 10:30:35 PM »
Ok thanks! I'll do it the first chance I get. I rode it 11 miles to work and didn't notice the headlight was out until I was about to head home. I hope I didn't cause more damage.
« Reply #11 on: May 05, 2014, 10:36:13 PM »
I seriously doubt it.
