Author Topic: Cheap tachometer for adjusting the idle speed?  (Read 1329 times)
hypophthalmus
« on: September 05, 2013, 10:21:37 PM »
Can anybody recommend a cheap tachometer for adjusting the idle speed? Unfortunately I already bought a digital multimeter with no Hz setting.
I was thinking of getting something like this: http://www.amazon.com/Tachometer-Kawasaki-Motorcycle-Generator-Snowmobile/dp/B0049IFX56/ref=sr_1_12?ie=UTF8&qid=1378419484&sr=8-12&keywords=tachometer
wheelsoffreedom76
Re: Cheap tachometer for adjusting the idle speed?
« Reply #1 on: September 06, 2013, 03:55:56 AM »
     The tach in your link will work fine for setting idle speed. The response time is the only real downside to that particular tach, which is not an issue when using to set idle, but not as effective for monitoring rpm while driving. Another option if you are looking to monitor more than idle speed is the tiny tach. http://tinytach.com/
   To really go all out check out Koso products. They have really nice instruments for scooters. http://www.kosonorthamerica.com/koso/scooter_met/
Pimpy1
  • Mo Hoes Power
« Reply #2 on: September 09, 2013, 01:35:33 AM »
I have one of those cheap tachs and it worked fine for me to tune my scoots. I just never permanently install one and I can use it on things like my lawnmower and chainsaw.
2011 Kymco Super 8 2t
2006 Kymco People 250
245luigi
  • Boston, MA
« Reply #3 on: September 25, 2013, 02:41:31 PM »
I took a look at the tiny tach site and under Standard TT2A Gasoline Tiny-Tachâ„¢ it says it measures 2 spark per revolution up to 8 sparks per revolution.
Is that sufficient for 2t?
Currently:
2012 Kymco Like70
72cc Malossi BBK
Dell'Orto PHBG 19 AS Carb
52 Pilot Jet
92 Main Jet
W7 Needle, 40 Slide
2T atomizer + bushing
Tecnigas Triops
Malossi Torque Driver
wheelsoffreedom76
« Reply #4 on: September 26, 2013, 01:00:54 AM »
  The specs for that one say "RPM reading adjustable from 1 spark per 2 revolutions to 8 sparks per revolution". It will work.
245luigi
  • Boston, MA
« Reply #5 on: September 26, 2013, 01:13:37 AM »
Great. Thanks!
Currently:
2012 Kymco Like70
72cc Malossi BBK
52 Pilot Jet
92 Main Jet
W7 Needle, 40 Slide
Tecnigas Triops
