Author Topic: needs left side mirror bracket  (Read 2932 times)
bunker buster
« on: September 07, 2013, 03:19:10 PM »
hi guys,
had an accident w/ my gv250 and the left side mirror came off. Where can I buy this bracket?  I checked with kymco parts website but they have no price , can only submit a wishlist. Please checkout the pics:
Urbestfriend
Re: needs left side mirror bracket
« Reply #1 on: September 07, 2013, 06:08:13 PM »
I recall I JB Welded mine several years ago.  Check Stadium Yamaha Kymco Parts List.
However more and more parts are being listed as "Call for Price".
bunker buster
« Reply #2 on: September 08, 2013, 07:45:01 AM »
is JB weld holds up to the vibrations?
« Reply #3 on: September 08, 2013, 01:39:13 PM »
  I just seen the mirror at powersportswarehouse.com    #88110 and 88120  for the mirrors take a look at the blow up pictures and pick out what you need,.
Urbestfriend
« Reply #4 on: September 08, 2013, 02:33:26 PM »
JB Weld (About $5.00) has held for several years.  My Brother's Alum. 635 cu. in.  1,200+ Hp.
Racing Engine is a combination of alum. welding and JB Weld and he won a national record two weeks ago.  You will find your plastic panels with broken tabs from vibration and worn out plastic threads from removing and replacing self-tapping screws.
Works excellent on these items. You can back up your bond with a piece of roughened up thin (pop can) alum. patch.
The only downside is it takes all night to cure for the regular JB,  but there is a quick cure.  Beats $15.00 shipping alone for new parts.
bunker buster
« Reply #5 on: September 08, 2013, 11:50:45 PM »
@de dee
Thanks for the link
@urbest friend
is this the jb weld version that'll work with the die cast bracket?
http://www.jbweld.com/product/j-b-weld/
Thanks too
Urbestfriend
« Reply #6 on: September 09, 2013, 12:25:56 PM »
Go to the Hardware, Auto Parts Store, Lowes and read the package.
bunker buster
« Reply #7 on: September 09, 2013, 04:11:40 PM »
JB weld products comes in different types of epoxy which particular one did you use on your side mirror bracket?
Urbestfriend
« Reply #8 on: September 09, 2013, 04:54:24 PM »
The black and red tubes, not the quick cure.  If this works,  which it should, you'll not only save money, but probably 2 weeks waiting on new parts.  Squeeze each tube about 1 1/2" long.  Mix together (I use a nail).   You'll have about 5 minutes working time.   Don't know what experience you have, but be willing to learn and save alot of money.
bunker buster
« Reply #9 on: September 09, 2013, 09:23:23 PM »
thanks B'friend!
mrbios
  • 2005 Kymco Grandvista 250cc
    • My YouTube Channel
« Reply #10 on: September 15, 2013, 05:53:29 AM »
hi guys,
Go to Home Depot and ask for a small roll of Metal (not plastic) Pipe Hanger / Pipe Strap.  Using this I made a bracket for my right side mirror when it broke off last Dec.  Works great - even better than the original - I'm getting ready to do the left side mirror because if vibrates - the repaired right side mirror spoiled me.
Tools needed: tin snips, drill bits, drill, nut and bolt or pop rivet (optional) gun.
PaulC
