Author Topic: Rollers Vs. Sliders  (Read 1888 times)
Kenho21
Rollers Vs. Sliders
« on: August 05, 2009, 10:12:20 PM »
What is the real advantage to replacing my 5.5 g roller weights with slider weights? What is equivalent to a 5.5 g roller (since rollers start at around 9 g)?
Thanks ,
Ken
Shaka
Re: Rollers Vs. Sliders
« Reply #1 on: August 06, 2009, 09:00:35 PM »
Mine seemed to accerlerate smother, and had a little higher top end.  You should be able to get them in 5.5 grams.
Kenho21
« Reply #2 on: August 12, 2009, 02:11:56 AM »
Shaka or anybody,
   Does anyone know what size slider weights the agility 50 uses?
Shaka
« Reply #3 on: August 12, 2009, 05:23:56 AM »
I'm not positive on the Agility.  I know that my zx50 uses 16mm X 13mm, that seems to be the most common size.
« Reply #4 on: August 12, 2009, 10:43:12 AM »
16 x 13 is correct
