Author Topic: ID of gas line for shut off valve  (Read 933 times)
jesionowski
« on: September 14, 2013, 11:53:32 PM »
Has anybody installed a shut off valve on the gas line for winter storage? and if so what size ID is the gas line. I want to run the carb dry this winter before storage.
Igonorance is never better than knowledge
wheelsoffreedom76
Re: ID of gas line for shut off valve
« Reply #1 on: September 15, 2013, 12:19:00 AM »
   Just unhook the vacuum line from the intake that goes to the fuel valve, and the valve will remain closed and allow you to run the engine till the carb is empty. You could also just open the carb drain screw and let the fuel run out the drain tube which would actually be better.
