Did you miss your
activation email
Scooters - 125 to 300
Downtown 300
STARTING THE DT 300 i
Topic: STARTING THE DT 300 i (Read 1740 times)
feebleknievel
Full Member
September 16, 2013, 08:38:28 PM »
sometimes and im not sure why.but when i turn the key on sometimes i get a battery light and the DT 300 won't start i can turn key off wait like 3 minutes turn it back on and it cranks has anyone ever had this issue
Joe7911
Jr. Member
Re: STARTING THE DT 300 i
September 16, 2013, 10:17:07 PM »
On my bike make sure your side kickstand is up then I turn key on wait till engine light goes off, then depress brake and hit starter.
If your bike does not work after doing this then you may have a problem and is best take to the dealer so that they can run a diagnostics.
feebleknievel
Full Member
September 17, 2013, 03:21:06 AM »
yeah it's not the side stand.and it's only done it 3 times but if i wait like 3 minutes it starts right up i think the battery is having issues cause when you 1st turn key on everything lights up.when it dont start the battery light comes on it's the original battery it's a used scooter so there is no telling what the previous owner used on the battery .yanno dang well if the dealership knows they ain't gonna tell .
West Tennessee, USA
Reply #3 on:
September 19, 2013, 09:12:43 PM »
I guarantee they DON'T know.....
ophelia
Sr. Member
Reply #4 on:
September 20, 2013, 01:20:24 AM »
Might be worthwhile to do easy checks like removing the seat tub and checking that the battery terminal cables are snug on the battery. Don't forget the underside push pin on the right side of the bike when removing the tub.
Battery could be marginal, but a dealership or service shop can test it.
2011 Kymco Downtown 300i
feebleknievel
Full Member
Reply #5 on:
September 20, 2013, 01:49:26 PM »
i'm gonna change the Battery out i my Dealership gave me a Deltran Lithium Battery Tender i think they run like $124.00 but i need to get a standard charger or a lithium charger my is a pulse charger could damage the battery
2011 300i downtown 82,265 KM.
Reply #6 on:
September 20, 2013, 08:31:38 PM »
Yes you need a lithium charger, if you have lithium battery, the charger has to balance the internal cells after the battery is charged, that is what I was told when I got a lithium battery,.
feebleknievel
Full Member
Reply #7 on:
September 28, 2013, 04:32:08 AM »
thanks de i called Deltran today n that's what they said also
8eeman77
Work hard, ride safe
Newbie
I'm a scooter loving Apiarist
Reply #8 on:
September 28, 2013, 02:27:53 PM »
Sounds like a battery problem to me, if not maybe electrical. A scooter to function properly needs plenty of power from the battery, once you start experiencing problems with scooter starting it usually means the battery needs replacing.
The Kymco DT 300i ABS is the best scooter you can get. I love it's carefree automatic ride. I would like to see kymco make a 600cc version but no heavier then the 300. I would buy it for sure
Back
