Author Topic: Auto Choke  (Read 15498 times)
erics
Re: Auto Choke
« Reply #15 on: May 11, 2016, 01:21:56 AM »
I just got my 2013 super 8 150 with 4K miles. I am having major problems with the auto choke. If I remove the choke from the carb and place my thumb over the hole ,  the engine runs great. The moment the auto choke goes back in place the engine would not accelerate.
I am looking for a manual choke kit
JRT123
Re: Auto Choke
« Reply #16 on: February 18, 2025, 09:15:53 PM »
All this talk about wrong wiring is irrelevant. The auto choke is heated with a coil that doesn't care which way round the wires are connected. If you are having a problem with the auto choke it is either that the choke is stuck or broken or else no power to it at all.
JRT123
Re: Auto Choke
« Reply #17 on: February 19, 2025, 12:35:18 AM »
Regarding the auto choke - not sure if you guys are aware - but it doesn't matter which way round the wires connect to the choke as it is just a heater coil - and it works either way round. If there is a problem with the choke then it is either the choke itself needs replacing or else check that it is getting 12v power on the leads.
Re: Auto Choke
« Reply #18 on: February 19, 2025, 04:55:15 PM »
Good point, but the guy might have solved it after nine years.
Re: Auto Choke
« Reply #19 on: February 19, 2025, 08:35:34 PM »
Had fun with the "remove" button here today.
If you didn't see it - you've missed nothing important, or adult.
Re: Auto Choke
« Reply #20 on: February 20, 2025, 10:11:55 AM »
Lol
