Author Topic: Click, Click, Click  (Read 1886 times)
Hiriser
Click, Click, Click
« on: August 06, 2009, 02:37:15 PM »
Click, click, click is all I get out of my friends Kymco Agility 50.  Battery is stellar, tested the voltage all the way to the starter and it is good according to the online manuals I found and downloaded because of this forum (thanks).  I've got spark, tested the primary and secondary coils using an ohm meter, fuses are good, obviously the relay is good since I can hear it clicking. The only thing I can see that isn't testing the way it should (once again according to the manuals) is the CDI.  I also tried kick starting the thing until my leg felt like it was going to fall off to no avail.
Saw another similar post about this but didn't see a resolution to the problem.
Can anyone point me in the right direction or is it most likely the CDI causing this problem?
The weird part is I own a Roketa that has an intermittent and similar problem.  My starter only kicks in once in about 20 tries.
Great forum with a lot of useful information.
