Author Topic: Opinions on Variators?  (Read 1315 times)
Smithg27
« on: September 19, 2013, 12:26:30 AM »
My OEM variator is trashed. Had a vibration, finished my ride home and took it apart. Broken.
The struggle was real!
So my question to you guys is which variator do you guys find best or what did you buy that worked much better than OEM?
I figure that now that I am forced to buy a new one I'm going to spend the money for something great.
Have 5.5g Dr. Pulley sliders but they now have some wear after this incident.
Smithg27
Re: Opinions on Variators?
« Reply #1 on: September 27, 2013, 03:05:09 AM »
So I went and got the Malossi Multivar. The scoot runs great now.
Very consistent acceleration with the new variator. Far smoother acceleration than the OEM variator and no flat spot like the OEM has. Higher top speed as well, but I'm 95% sure that's just due to the shorter drive boss that came with the kit.
The white counterspring helps a bit with re acceleration and holding speed uphill but I will probably buy a 1500rpm spring soon.
Thanks for all the replies and help! You guys are the best!   >:(
« Reply #2 on: September 29, 2013, 04:46:45 PM »
Looks like you did good on your own. thats good. I was going to tell you the stock variator is good and ok to use they need raplced from time to time any ways.
