Did you miss your
activation email
Scooters - 50cc
Like 50 2T
Is it possible to replace the Like50 speedo with the Like200i
Topic: Is it possible to replace the Like50 speedo with the Like200i (Read 1235 times)
245luigi
Sr. Member
Boston, MA
September 19, 2013, 01:40:03 AM »
Im starting to go past the stock speedo readings on the 50. I see that the 200i has more mph markings. Im wondering if a simple swap would work?
Currently:
2012 Kymco Like70
72cc Malossi BBK
Dell'Orto PHBG 19 AS Carb
52 Pilot Jet
92 Main Jet
W7 Needle, 40 Slide
2T atomizer + bushing
Tecnigas Triops
Malossi Torque Driver
245luigi
Sr. Member
Boston, MA
Re: Is it possible to replace the Like50 speedo with the Like200i
September 25, 2013, 01:25:29 AM »
I havent found any posts/info regarding this but based off cursory research, it seems its possible. I would just need a 200i dash display and the speedo gearing for the front wheel and would be a simple swap unless im missing something...
Currently:
2012 Kymco Like70
72cc Malossi BBK
52 Pilot Jet
92 Main Jet
W7 Needle, 40 Slide
Tecnigas Triops
Back
