Author Topic: LO FUEL-Light on CAP lock stuck  (Read 1249 times)
KYMCOcruiserGirl
« on: September 22, 2013, 12:54:07 AM »
Need ride to go to work Monday!
Bright yellow LO-Fuel light's on, but cannot unlock cap.
Same key let me refuel last month. Same key starts her up.
Locksmith gave up. Any ideas, anyone smart?
Email: rlscatalani@gmail.com
Modify message
max oradea
Re: LO FUEL-Light on CAP lock stuck
« Reply #1 on: September 22, 2013, 02:42:11 PM »
should be a simple jam, try pushing the cap down while turning the key, gently left and right and see if that works.
Mike-the-Bike
« Reply #2 on: September 22, 2013, 02:53:02 PM »
Try shooting a little "PB Blaster" into the key hole and doing what Max suggested.  PB BLaster is a penetrating lubricant 100x better than WD-40.
Mike-the-Bike
« Reply #3 on: September 22, 2013, 03:10:55 PM »
Also, once you get the cap off, spray more PB Blaster on the locking mechanism, and let it soak in for a few hours after working the key several times.  You can get PB Blaster at most automotive stores, Lowe's, or maybe Walmart; it's only $5.00 a can.
Hairy Bob
« Reply #4 on: September 23, 2013, 08:20:23 AM »
Well there you go, I had the exact same problem a couple of months ago. I sprayed Lannox, a heavy duty anticorrosive lanolin lubricant directly into the key slot, worked the key a few times, and bingo, fixed. Had no trouble since. So anything similar should do the job.
Regards,
Hairy Bob.
Damn the torpedoes .. full steam ahead !
« Reply #5 on: September 23, 2013, 08:45:10 AM »
Three fast replies on the Venox forum! Wow!  a damsel in distress makes the difference....  ;D
By the way kymcocruisergirl... you said locksmith gave up? What kind of locksmith was he? The first thing to suspect a stuck lock is corrosion and the first solution would be lubrication.... any handyman can do that... hmmm...
« Last Edit: September 23, 2013, 08:49:08 AM by Vivo »
Mike-the-Bike
« Reply #6 on: September 28, 2013, 03:37:09 PM »
Well?  Did you get the cap fixed?
