Author Topic: Agility 50 air filter.. when to replace it and where to buy it?  (Read 1554 times)
stoneboy
« on: September 23, 2013, 02:04:22 AM »
Hello all,
I have had my 2013 Agility 50 for about a year now. It has got a bit more than 7000km on it. It runs well without any issue. I changed engine oil every 1000 km. Now I am thinking that it might be time to replace air filter or just clean it. Do you think that it is time to replace it? If so, do you recommend any good place online where I can order it?
Thanks so much!
Stoneboy
Re: Agility 50 air filter.. when to replace it and where to buy it?
« Reply #1 on: September 23, 2013, 02:31:49 AM »
Clean it first with compressed air, then see if sunlight can still  pass thru the element.. if it does not ... time to replace...
stoneboy
« Reply #2 on: September 23, 2013, 03:34:41 PM »
Thanks, Vivo..
Well, I don't have a air compressor. Will Shop Vac work by sucking dirt from the dirty side? Also, where would be a good place to buy it online?
Thanks!
« Reply #3 on: September 24, 2013, 02:04:41 AM »
you could always up jet to a 82 or bigger and a open air filter.
kennybones
« Reply #4 on: October 18, 2013, 05:48:34 PM »
ive just upped to an 82 do i have to use a performance air filter or as i think your sugesting just remove the air filter element i have just bought a new one it feels like a mistake
can you reomend any perfomance filters
the bike is always running rich infact it seemed to do it even before i changed the jet i have stripped the carb down and cleaned it using carb cleaner and reset the pilot screw but it always seems rich
it hesitates and back fires more since i changed the jet
the emsison system was blanked of before i got it is it worth reinstating it or just leave it disconected
anyone who can help with this will be greatly appreciated
thanks
« Reply #5 on: October 18, 2013, 09:08:34 PM »
any scooter shop should have a good open air filter for ya.
