Author Topic: carb vacuum hose??  (Read 735 times)
ehershey
carb vacuum hose??
« on: September 25, 2013, 01:02:44 AM »
Bought a used agility 50. It had sat awhile so I decided to clean the carb as it seemed a little pokey. As I was taking apart the carb, I notice the vacuum hose that comes off the bottom of the carb (see photo) was not connected to anything. Where does it go or is it supposed to be open to the atmosphere?  Thanks!
wheelsoffreedom76
Re: carb vacuum hose??
« Reply #1 on: September 25, 2013, 02:20:45 AM »
   That is the drain hose for the carb. It should just hang down towards the ground. There is a valve operated by opening a slotted screw which drains the bowl through that hose if you need to drain the carb for any reason.
« Reply #2 on: September 25, 2013, 09:13:17 PM »
x2
