Author Topic: Xciting 500 Compression loss  (Read 2030 times)
500_Monkeys
« on: September 29, 2013, 05:27:21 AM »
Hello All,
My scoot is almost 2 years old and about to expire it's warranty.  I've reported a compression loss of 25psi.  The dealer I got it from has confirmed the compression loss via a leak down test and said that he could hear the air coming out of the engine/crank.  He seemed to think that it wasn't worth worrying about and said that he would be hard pressed getting it fixed under warranty.
Would you like to have a 25psi compression loss after just 18,000klms/11184mi?
What are people's thoughts?
MYD 2009 Kymco Xciting 500Ri ABS - Assembled October 2011
BigOrange
Re: Xciting 500 Compression loss
« Reply #1 on: September 29, 2013, 07:16:27 AM »
polite but furious.  Call spartanburg sc asap.  Kymcousa and get it covered under warranty.
I wish I could ride more and drive less!
2009 Xciting 500i White!
2007 Xciting 250 Orange!
sissy mary
« Reply #2 on: October 02, 2013, 10:29:12 PM »
Tighten up the head bolts first, and adjust the valves while you are there, and if that does not work then it is a ring on the piston. It should be covered under warranty. Never heard of this happening before?  >:( :( :'( :-*
500_Monkeys
« Reply #3 on: December 07, 2014, 12:28:33 AM »
Thank you all.  ( Sorry for late reply )
Update:  Couldn't be bothered going 30 rounds with the heavy weights ( Dealer + KYMCO ).  They were willing to fix the issue if I produced receipts for all my parts that I have been servicing the bike with.
Are you really going to keep a receipt for a spark plug or Oil filter?   So, in short I let the matter go.
Cheers!
