Author Topic: Help with Center Stand  (Read 2815 times)
Moptch
« on: September 30, 2013, 03:01:29 PM »
I recently purchased a 2006 250 XCiting and I am really enjoying it.  I cannot, however, figure out how to put the bike on its center stand.  Anyone have any tips?
ScooterCommuter
Re: Re: Help with Center Stand
« Reply #1 on: September 30, 2013, 07:31:50 PM »
Same technique as for any larger bike.
Start with it on its side stand. Facing the bike, put a little weight on the center stand lever so the nearside foot touches the ground firmly. With one hand on the bars and the other on the grab rail, rock the bike upright until both feet of the center stand are planted. If you need to switch your grip around at this point, you can. As long as you keep downward pressure on the center stand lever with your foot, the bike can't fall down. Now pull gently upwards on the grab rail and put your weight on the lever.
Once you get that technique down it's pretty much effortless. At least, it is for me with my 500 and I've seen even fairly small ladies manage it with big machines exactly the same way.
wakeupmaggie
« Reply #2 on: September 30, 2013, 07:42:04 PM »
I had a hard time at first too and I had remembered the dealer putting the bike on the stand effortlessly.  So I knew it couldn't be that difficult.  Now it's not a problem though it does take a little practice.
Somerset County, New Jersey
DT300i
« Reply #3 on: October 01, 2013, 01:28:32 AM »
The first time I did it, the scoot out balanced and the handle bar hit my car's front fender... left a dent...  >:(
CosmoKorny
« Reply #4 on: October 01, 2013, 09:30:52 PM »
Youtube has some good (and some not so good) video tutorials that should help out.  And once you get in on the centerstand, buy an angle grinder and fix the sidestand angle.
Normal is boring.
2006 Kymco Xciting 250
Moptch
« Reply #5 on: October 19, 2013, 06:35:44 PM »
Thanks for everyone's help.   It turns out the previous owner had put the bracket under the center stand for some reason, thus preventing its operation.  Got it working now though!
