Author Topic: two lights above the headlight  (Read 3017 times)
TuttoCambia
« on: August 10, 2009, 08:07:25 AM »
Does anyone know what the two lights above the headlight are on agility 50..I just noticed them but I cant find a switch to turn them on. ive tried all my headlight switches but nothing turns them on. I have a spot just above the starter button that looks like a switch could be installed there. I dont see why they would install the lights on the scooter if theres no switch for them. any ideas of what these lights are?
Re: two lights above the headlight
« Reply #1 on: August 10, 2009, 10:20:10 AM »
..they are "Position" lamps, and they are not wired into any circuit...at least mine were not.
..the lamps are not drawn into the electrical schematic in the service manual that I downloaded, but there are 2 rear position LEDs drawn on the schematic, that I havn't found on my scoot yet...???
..I did, however, wire the front lamps into the bright beam wiring, which is all I use, and changed the incandescents to LEDs...
peace
« Last Edit: August 10, 2009, 05:26:10 PM by wordslinger »
axy
« Reply #2 on: August 10, 2009, 12:57:52 PM »
..they are "Position" lamps, and they are not wire into any circuit...at least mine were not.
peace
I have a number of interesting things in my A125 manual that do not exist in reality. For example, manual gasoline tank-reserve valve.
Also, as I already pointed out, the procedure for oil change is described completely wrongly.
Kymco Agility 125 2008
codger78
« Reply #3 on: September 16, 2009, 03:20:36 PM »
The response made to info@kymco.com as follows:  "These lamps are used in other parts of the world as turn signals.  However, in the U.S. they do not meet the height and spacing requirements for legal highway use."
borrowed dust
Urbestfriend
« Reply #4 on: September 16, 2009, 07:25:04 PM »
Urbestfriend replaced the bulbs with Ambers,  hooked up
a Flasher and a Switch and they work like 4 way signals.
« Reply #5 on: September 16, 2009, 07:26:25 PM »
..cool idea!
scooterman11
« Reply #6 on: December 24, 2010, 10:16:09 PM »
@axy
You where saying something about having two leds wired in to the system in the back
how did you find those, where did you find a wiring diagram?
stuh7
« Reply #7 on: December 30, 2010, 12:52:32 PM »
in england they are side lights and the switch is just above the starter it is a 3 position switch 1=off 2=side lights 3=main beam/headlights
there a pain in the arse as i have blown 2 bulbs in 6 months so just got a set of l.e.d one for it!!
I may be small but look how far i will go!!!
Blammo
« Reply #8 on: January 15, 2020, 08:57:56 PM »
Hey wordslinger. How did you wire those two lights into the high beam switch?
« Reply #9 on: January 16, 2020, 02:00:59 AM »
Be aware his remark was made 11 years ago. And hasn't been active here in 4 years.
« Last Edit: January 16, 2020, 02:03:41 AM by Stig »
