Author Topic: Front Brake & Grip Covers  (Read 1495 times)
TLRam1
« on: October 12, 2013, 03:51:18 AM »
On my recently acquired Kymco People S 250  w/300 miles on it the front brake takes more travel than the rear brake. I measured the lever from the grips thinking that might be it, same distance.
Is that by design so someone does not use too much front brake or do I need to look further into this? Not spongy but takes more pull.
Put on these grip covers tonight, just rode down the alley, I think I will like them but I do need more time trying these out. This makes the grips a little over 1 1/2 inches.
« Last Edit: October 12, 2013, 05:49:12 AM by TLRam1 »
Terry
10 Kymco People S 250
87 Yamaha Riva 200 (Sold)
Allen TX (Dallas)
cli-maxridinggear.com
Re: Front Brake & Grip Covers
« Reply #1 on: October 12, 2013, 03:57:10 AM »
The front brake lever usually travels around an inch or less... how much is yours?
Nice grip covers by the way...
TLRam1
« Reply #2 on: October 12, 2013, 05:51:31 AM »
Thanks.
If you are measuring from about the middle of the grip to the lever, the front moves about an inch or a bit (1/16) under, the rear moves about 1/2 inch.
Terry
Allen TX (Dallas)
« Reply #3 on: October 12, 2013, 06:19:27 AM »
So, in an emergency situation your rear brakes engages a split second ahead of the front once you squeeze both grips at the same time...hmmm...  If the brakes are not spongy, they're good../  ;)
Does your scoot have a dual circuit system? meaning two separate masters one front and one for the rear since your scoot have discs for both front and rear.... My scoot has a drum rear (mechanical) and disc up front (hydraulic)... If one fails, I still have the other...
TLRam1
« Reply #4 on: October 14, 2013, 07:25:23 AM »
Yes it does have separate masters for the front and rear, the front has dual disk and maybe that is it, I don't know but I do not like it. I am better at modulating my brakes by feel and I lose braking power on the front because I have to pull it in much more, but maybe for the masses it prevents surprises.
Terry
Allen TX (Dallas)
« Reply #5 on: October 14, 2013, 08:18:58 AM »
My brakes up front engages first... I even use the front earlier than the rear...
TLRam1
« Reply #6 on: October 14, 2013, 02:23:29 PM »
When I wear gloves the grip covers make it easier to grab the grips. This makes the scooter grips about the same size as my other street bikes.
Terry
Allen TX (Dallas)
