Author Topic: Tire size  (Read 1561 times)
Mike2423
Tire size
« on: October 12, 2013, 05:41:37 PM »
Will stock Uxv 500 se model fit 27 inch tires with no lift tires would be 27.11 rear and front 27.9
Blue500SEi
  • 2012 UXV 500SEi all stock
Re: Tire size
« Reply #1 on: September 30, 2014, 09:22:50 PM »
I was told maybe with a clutch kit upgrade.  On the 500 26" tires are the recommended max.  Potential issue is that the engine just won't spin them fast enough to clean out the treads in muddy conditions.
Driving slow in low gear and just rock crawling it ought to work.  I would try it if I could demo some big tires just to see how it handled.  ITP Mud lite 26" 12-12 tires are on my wish list.  I definitely want a bit more ground clearance as well.
twistedgrip
  • DEALER- Ride Hard, Ride Proud, Ride Free
Re: Tire size
« Reply #2 on: December 03, 2014, 06:21:20 PM »
You should be able to go to a larger tire with a clutch upgrade 8)
Re: Tire size
« Reply #3 on: December 03, 2014, 09:25:30 PM »
Look up (on the search) Darkside.
You'll find a car tire thread that might help. You don't have to upgrade the clutch for a larger tire... Reduce the roller weight to get the same RPM as the smaller diameter tire.
