Author Topic: CELP Codes for 2012 Yager GT 200i  (Read 3038 times)
Fej
« on: October 14, 2013, 02:29:04 PM »
I'm trying to figure out the CELP codes for my 2012 Yager.  I think that the diagnostic blinks on the 2012 may be different than the 2010 model.  The 2012 Yager model appears to use the blink pattern similar to the 2012 Like models where 1 second flashes signify the tens digit and 1/2 second flashes signify the ones digit.  Does anyone out there have a 2012 Yager service manual?  I've got a copy of the 2010 version but I want to make sure that the codes themselves haven't changed between the models.  I'm getting one long flash and six shorter flashes which would appear to indicate a code 16 fault - Cylinder Head Thermo-sensor fault - based on the 2010 manual.  I've been seeing this happen quite a bit over the last month so I'd appreciate any feedback you guys have.  Thanks.
Jeff T.
Re: CELP Codes for 2012 Yager GT 200i
« Reply #1 on: December 20, 2013, 09:30:04 PM »
Have you PMed Motorandy123 yet? He wound up as one of the Yager "gurus" on this forum. He would either know or know where the answer is. When did they discontinue the Yager? I was thinking it was 2012. You might try an ECU reset and see if the code comes back. The reset, if I remember correctly, is key off, open throttle to stop, key on for 10 seconds, close throttle, key off. This should erase any codes. Then key back on and wait. Should go thru self-check and CELP light should remain out with key on.
You been waitin' a LONG time on this one! Sorry.
Yager200i
« Reply #2 on: June 11, 2014, 04:19:03 PM »
Here's the Diagnostic Trouble Code (DTC) list (thanks goes to MotoRandy123 for posting this elsewhere), for future reference:
1 P0217 Engine overheating
2 P0335 Encoder fault
3 P1120 TPI adaption fault
4 P1121 TPI range fault
5 P1122 TPI velocity fault
6 P0560 Battery voltage range fault
7 P0110 Air temperature sensor fault
8 P0410 Idle air bypass valve fault
9 P0505 Idle speed adaption fault
10 P0251 Fuel injector fault
11 P0350 Ignition fault
12 P0230 Fuel-pump relay fault
13 P0219 Engine max over-speed fault
14 P1560 Transducer power supply fault
15 P0700 CVT threshold exceeded fault
16 P0115 Engine temperature sensor fault
17 P1561 Temperature gauge fault
18 P0650 Check engine lamp fault
19 P1410 CO potentiometer fault
20 ?
21 P0105 Manifold pressure fault
22 P1110 Angle detect sensor fault
23 P0136 O2 sensor circuit malfunction
24 P0141 O2 heater/O2 sensor circuit malfunction
25 P0171 Close loop fault
Fej
« Reply #3 on: August 06, 2014, 10:10:36 AM »
Thanks Yager200i for posting the list to my thread!  I'm getting code 16 (one slow, six fast blinks).  I'll have to look closer at the engine temp sensor.  First I need to get a new battery though.  My Yager won't start up even after hours on the battery charger.  Starter seems to be working and from what I've read a number of people have had to replace battery in first two years.  Anyway, thanks again!
One more question Yager200i.  Where did you get a hold of your Kymco diagnostic tool?  Is it worth spending the money on vs. just checking the codes for the CELP light blinks?
« Last Edit: August 06, 2014, 10:14:53 AM by Fej »
Jeff T.
Yager200i
« Reply #4 on: August 11, 2014, 11:17:56 PM »
I'd say it is, if you're having or suspect you're having any problems. But these bikes are so trouble free it's a waste of money unless you're servicing a lot of bikes. If you're in the SF Bay Area, PM me, drop by, and you can use mine.
