Author Topic: REMOVING THE FRONT BAODY COVER HELP  (Read 10179 times)
ophelia
Re: REMOVING THE FRONT BAODY COVER HELP
« Reply #15 on: April 04, 2014, 05:09:13 PM »
Those are all the screw locations. Just take your time. Be careful with the big Y-shaped piece of plastic on the front of the bike. The plastic clips might snap if you don't pull straight out.
2011 Kymco Downtown 300i
mousejunks
« Reply #16 on: November 16, 2015, 08:35:06 AM »
There is a super easy way, only takes 5 minutes:
1) remove the windscreen (4 allen bolts + 1 bolt under badge)
2) loosen 6 screws at the rear-side of the front section
3) pull the whole front section out by tilting it forward.
Do this if you need to change the front headlight bulbs, inidcator bulbs, 12V fuse or relays.
'09 Kymco Espresso 150i
'17 Kymco Downtown 350i ABS
kneeslider
« Reply #17 on: October 23, 2016, 02:09:25 AM »
Please explain this in detail, i tried it and it didn't even budge.
2019 Yamaha X-Max 250
« Reply #18 on: October 23, 2016, 06:29:49 PM »
  there is two bolts under the Y piece that has to be removed,. and two screws under the fender
