Author Topic: MAN I DID A DOOZY TODAY BRAIN FART BIG TIME .LOL  (Read 2866 times)
feebleknievel
    • Kickin Country hITS
« on: November 03, 2013, 04:06:49 AM »
went to change my oil today on the DT 300 drained the oil sat there for a few minutes.open my Castrol poured it in and realized i forgot to change the damn oil filter.lol really serious .lol i did .lol so tomorrow i do it all over again. wish me luck ....lol
Re: MAN I DID A DOOZY TODAY BRAIN FART BIG TIME .LOL
« Reply #1 on: November 03, 2013, 01:56:24 PM »
isnt that what you call a senior moment,.  I have a few of those,  I didnt tie down the temp shelter, and it was across the yard yesterday,  a 12 x 20 has a lot of lift,  so I buried 2 x 2 patio stones 1 1/2 ft. and ran a cable to tie it down ,I hope that will do it,.
feebleknievel
« Reply #2 on: November 03, 2013, 04:03:20 PM »
so i hope the gear oil is i put it in until it starts to come out i know it says .023L but as you say my senior brain can't calculate L to pints or quarts .lol
« Reply #3 on: November 03, 2013, 04:50:43 PM »
  I did that too,  first time , the air filter was soaked with oil in a short time,  get one of those meat  injector things at walmart it has mm. marked on them,
« Reply #4 on: November 03, 2013, 08:32:55 PM »
I slid under my wife's new Toyota, pulled the plug and drained it into the dirty pan. Pulled it out - fortunately I can tell the difference between ATF and engine oil - even if I can't tell the difference between the drain plugs!
Did this on a Fri night - dealer/parts not open till Monday. As I told my son - "let that be a lesson to you ! , now - let's go clean the toilet with the cat."
« Last Edit: November 03, 2013, 08:35:54 PM by Stig »
feebleknievel
« Reply #5 on: November 03, 2013, 11:34:00 PM »
Buncha Old Farts on scooters .lol okay changed oil today again  2 days in a row this time the filter made it in.lol 1st time forgot to clean the oil screen did that today done.gear oil drained and replaced with 75-90 it took 300 ML just like my older burgman use to done.works good .untill next time same Bat time same Bat Channel :)
Adept
  • Empaticus Maximus
« Reply #6 on: November 07, 2013, 08:41:38 AM »
My fear, I forget to put back the oil drain bolt. I always check it twice.  :)
I always put everyting (oil, filter, etc.) front of me, because if I see the parts, I won't forget anything...
I have a barely used (200km)14gr Dr Pulley rollers to SELL!! Send a PM if you interested in...
« Reply #7 on: November 07, 2013, 09:06:51 AM »
  thats why I have my wife shes not nagging, shes reminding me,
brandonbosch
« Reply #8 on: November 12, 2013, 01:45:30 AM »
Hey! How do you remove the filter? Is it in that cylindrical shape area under the dipstick?
feebleknievel
« Reply #9 on: November 12, 2013, 02:13:57 AM »
here you go hope this helps
brandonbosch
« Reply #10 on: November 12, 2013, 03:05:21 AM »
Feeble I owe you a beer. Awesome. Thank you so much. Above and beyond!
de-dee
« Reply #11 on: November 12, 2013, 03:18:12 AM »
   I always change the oil after a good run to heat the oil, and change the oil hot befor it has time for the crap has time to settle,  and the same for the tranny oil,.  the two bolts on the left side one is drain and the other is the wire mesh filter , remove the filter with needle nose plyers very gentle it comes out easy, and blow clean and do not over tighten it is alum. nut cap,  use reg. oil for break in, I switched to syn. oil at 1,000 miles,.
feebleknievel
« Reply #12 on: November 12, 2013, 05:15:11 PM »
No Problem that's what were here for to help .hope everything went well Brandon
