Author Topic: Stuck allen head screw on the front brake  (Read 1526 times)
Adept
  • Empaticus Maximus
« on: November 04, 2013, 07:28:34 PM »
I have tried to change the brake pads in my front break.
There is an allen screw, holds the pads. This screw is stucked.
I bended an allen key, I tried hammer, WD40, pipewrench, everyting. It is not rusty. How can I move it?
Any solution?
I have a barely used (200km)14gr Dr Pulley rollers to SELL!! Send a PM if you interested in...
Re: Stuck allen head screw on the front brake
« Reply #1 on: November 04, 2013, 09:56:17 PM »
   I use a hex socket driver with a impack screw driver 18 volt or a 3/8 air gun , if you use to much power it will break the bolt,. impack is the best for me,.
feebleknievel
    • Kickin Country hITS
« Reply #2 on: November 05, 2013, 01:09:11 AM »
never use WD40 on stuck bolts best thing to use is PB Blaster 16-PB Penetrating Catalyst.best in the world if the PB Blaster don't make it move you might want to try heat
« Last Edit: November 05, 2013, 06:40:23 AM by feebleknievel »
Adept
  • Empaticus Maximus
« Reply #3 on: November 05, 2013, 12:07:28 PM »
Here in hungary we dont't have that  Pb Blaster in  the stores...
How to use the flame? Can I demage the brake valve, or the rubber parts with the heat??
« Reply #4 on: November 06, 2013, 01:46:41 AM »
Are you sure you are turning the screws the right direction? just asking... there are penetrating oils available better than wd40, try them first...
Adept
  • Empaticus Maximus
« Reply #5 on: November 06, 2013, 08:59:52 PM »
I screwed a few beside this, while I changed the oil, and the rear pad... And I wasn't alone (my friend and the repair guy)
feebleknievel
« Reply #6 on: November 07, 2013, 07:04:43 AM »
purchase PB Blaster online amazon sells it
Adept
  • Empaticus Maximus
« Reply #7 on: November 07, 2013, 08:36:42 AM »
I got a flame heater (Dremel), so today I will try to give a little warm... :)
