Author Topic: Super 8 150 Carb Adjustment  (Read 3137 times)
Sweetlou
« on: November 12, 2013, 06:22:33 PM »
Long story short... the auto choke wiring was backwards on my 2012 People 150. Now that the auto choke is working properly (pulled it off, tested it, works) when the auto choke goes "off" and the fuel circuit is leaner, the bike runs rough. Previously, when the auto choke not functioning and the fuel circuit being much richer, the bike ran great once warmed up. However I was getting full throttle bogs. Bike is stock with 2200K.
Anyway, I pulled the cap off the fuel mixture screw but there is no screw inside... just a round brass fitting with a flat side. Pic:
How do I turn this screw-type thing?
Thanks
Lou
« Last Edit: November 12, 2013, 06:26:40 PM by Sweetlou »
big blue
Re: Super 8 150 Carb Adjustment
« Reply #1 on: November 12, 2013, 07:37:10 PM »
Check your local motorcycle shop or auto parts supplier. They sell carb adjusting tools with various tips on them. Just find one that matches your mixture screw. They usually look like this and have a flexible shaft to reach into tight places.
« Last Edit: November 12, 2013, 07:42:32 PM by big blue »
SaltyDog
« Reply #2 on: November 13, 2013, 07:07:33 AM »
It's subtle, but it is actually single-"D" shaped, and takes a bit like this:
http://www.amazon.com/Motion-Pro-Replacement-D-Shaped-08-0242/dp/B003CMWC4U
« Last Edit: January 29, 2014, 06:40:21 AM by SaltyDog »
« Reply #3 on: November 13, 2013, 07:16:37 AM »
Or if you have a .223 caliber shell casing... you can flatten one side to make the "D" shape...
« Last Edit: November 13, 2013, 07:18:35 AM by Vivo »
Sweetlou
« Reply #4 on: November 13, 2013, 04:40:35 PM »
Cool! Just ordered the tool off amazon. Vito, neat idea for a adaptation... but for $5.00 I will stock my tool box  with the proper tool :)
Lou
Sweetlou
« Reply #5 on: November 22, 2013, 01:22:52 AM »
OK, so this is strange. I ordered the Motion Pro D Shape 08-0242 tool and it is too large for the screw? Anyone have any insight?
I ordered the exact bit linked above.
Thanks
Lou
« Last Edit: November 22, 2013, 01:28:51 AM by Sweetlou »
