Author Topic: ZX50 Super Fever won't start. (Solved)  (Read 5346 times)
danovr
« on: November 13, 2013, 10:13:43 AM »
 ;DHello
I have just bought  a second hand super fever unseen. The lady who sold it said it worked ok, but stalled after a while. I thought this would be a piece of cake. However, now the scooter won't start at all. The spark is good, but it will not fire. I've tried with start gas, petrol down the spark plug hole, cleaned the carb and changed the battery. Still not even a single cough neither with kick or starter. I think the compression is ok for a 50 cc. I also have downloaded the workshop manual, but I'm running out of ideas. Does the CDI influate the ignition timing?
Any tips will be greatly appreciated, thanx.
Daniel
« Last Edit: December 01, 2013, 06:16:32 PM by danovr »
danovr
Re: ZX50 Super Fever won't start. Please help me!
« Reply #1 on: November 13, 2013, 03:46:05 PM »
I tested the compression now, and it was 120 psi. Shouldn't this be sufficient to start?
I hope someone in here can give me an idea of what to do next.
« Last Edit: November 13, 2013, 04:22:23 PM by danovr »
LoveMyKymco
« Reply #2 on: November 14, 2013, 12:17:36 AM »
Hi Dan, 120 is great compression. CDI definitely is for spark. You are sure you have spark?
danovr
« Reply #3 on: November 14, 2013, 08:29:57 AM »
Thanx for the reply LoveMyKymco.
Yes I have spark, but is it possible that it can come at the wrong time?
Is it possible to measure the compression below the piston?
naughty lee
  • 64 mph and pushing
« Reply #4 on: November 14, 2013, 01:09:48 PM »
Double check your plug, remove supressor cap and refit. Gap plug to 0.9mm. Also check fuel feed pipe for kinks/nips and blocked inline filter.
danovr
« Reply #5 on: November 22, 2013, 12:00:11 PM »
Fitted a new spark plug today (br8hsa). and during the first attemt to start there was a couple of coughs. but never started  >:(
nomadrac
« Reply #6 on: November 23, 2013, 04:56:01 PM »
If you don't have a service manual, Google for it and go thru the troubleshooting in Ch. 15 for your electrical system. check resistance values against service manual specs. maybe you have a week spark, or bad CDI,  the CDI is powered by AC voltage, check generator too
naughty lee
« Reply #7 on: November 25, 2013, 01:21:34 PM »
Try just using the kickstart WITHOUT any throttle, if it won't go after a couple of dozen kicks, it's possible that the last owner might have dicked about with the carb settings.
Where are you?
danovr
« Reply #8 on: December 01, 2013, 05:01:37 PM »
Finally got it going now :D
Thanks for all your help.
It was actuallu the reed valve that didn't close properly.
« Last Edit: December 01, 2013, 06:15:10 PM by danovr »
LoveMyKymco
Re: ZX50 Super Fever won't start. (Solved)
« Reply #9 on: December 02, 2013, 05:36:23 PM »
Nice and cheap fix. Congrats and enjoy the scoot!
nomadrac
« Reply #10 on: December 05, 2013, 02:44:14 AM »
. How did you figure the reed valve wasn't functioning correctly?
danovr
« Reply #11 on: March 08, 2014, 11:34:35 PM »
I had it out, and could blow through it both ways. Dismanteled and cleaned it, and it worked.
