Author Topic: Please help.....Super 8 150 problems  (Read 6756 times)
bbiggddaddy
  • I have owned 6 different Kymco scooters. Agility 50, Agility 125, People 50 2T upgraded 72cc, People 50 4t, People 150, and now Super 8 150.
  • I am a Kymco scooter enthusiast.
« on: November 13, 2013, 07:45:40 PM »
I left to go to work this morning and about 5 miles into my ride my scooter started bogging down and just cut off. It will start but if I give it any gas it just bogs down and shuts off. I removed the filter and replaced it and no difference...same thing happening. Any help at all would be appreciated. I just got a new job and this is my only transportation.
"Never argue with stupid people, they will drag you down to their level and then beat you with experience."
-Mark Twain
tortoise
Re: Please help.....Super 8 150 problems
« Reply #1 on: November 13, 2013, 09:07:21 PM »
Observe if the carb slide and needle assembly is rising properly . . video.  If not, check diaphragm for tears.
bbiggddaddy
« Reply #2 on: November 13, 2013, 09:22:51 PM »
I opened up the card and everything seems to be working properly. Put everything back and still getting the same results. I opened up the air breather and sprayed carb cleaner while at about 3/4 throttle and it revs up and starts backfiring. I checked the valve clearance and it is correct. Any more suggestions?
-Mark Twain
tortoise
« Reply #3 on: November 13, 2013, 10:00:13 PM »
Ignition troubleshooting.
bbiggddaddy
« Reply #4 on: November 13, 2013, 10:30:58 PM »
Everything I have tried has not made any difference in the way it is running. So far I have drained the fuel tank and replaced the fuel filter. I replaced the spark plug. I opened, inspected, and cleaned the carb. I replaced the gas cap. I checked for vacuum leaks. I checked and re-checked valve clearance. Nothing that I have done has made it run above idle. It starts and idles as it always has, but just as soon as I give it any throttle is starts bogging down. I have to walk away from it for the day..........just getting frustrated now. I am open to all suggestions.......if there is anything I have overlooked please please please help me figure this out. I have been working on this since 7am this morning and am my whits end. I even swapped out the cdi and that made no diffference as well.
-Mark Twain
« Reply #5 on: November 14, 2013, 01:31:55 AM »
Does it idle properly? and dies when you give gas? Hard starting?
bbiggddaddy
« Reply #6 on: November 14, 2013, 01:51:29 AM »
It idles properly....starts easy....but once you give it gas is starts dieing out. Can't figure out what is wrong.
-Mark Twain
« Reply #7 on: November 14, 2013, 02:32:27 AM »
The usual causes are kinked fuel line or vacuum line or one of the jets is clogged.
bbiggddaddy
« Reply #8 on: November 14, 2013, 03:07:31 AM »
I got it figured out, and by the way if you had read my earlier post you would have seen that I had already checked all of that in the first place. Just saying.
-Mark Twain
tortoise
« Reply #9 on: November 14, 2013, 03:31:09 AM »
got it figured out
Posting the deficiency may help others researching this topic.
bbiggddaddy
« Reply #10 on: November 14, 2013, 03:57:39 AM »
I will say that it was not anything that anyone here suggested.
-Mark Twain
PeTroL42
« Reply #11 on: November 15, 2013, 08:59:43 AM »
Everyone here was trying to help you out the best that they could so are you going to be a douche bag and not share what your solution was?
bbiggddaddy
« Reply #12 on: November 16, 2013, 12:08:44 AM »
I was getting ready to post the fix for this problem. I guess you have never had a bad day.......but after your last comment.......I think not.
-Mark Twain
« Reply #13 on: November 16, 2013, 01:15:38 AM »
He's just ashamed to post his fix...  :P
bbiggddaddy
« Reply #14 on: November 16, 2013, 03:08:15 AM »
Uh huh. Rode 100 miles today and no issues at all = problem solved.
-Mark Twain
