Did you miss your
activation email
Scooters - 50cc
Like 50 2T
How much "gunk" should be coming out of my exhaust?
Topic: How much "gunk" should be coming out of my exhaust? (Read 1468 times)
245luigi
Sr. Member
Boston, MA
November 18, 2013, 10:09:22 PM »
After about 400 km (248 mi) this is what my exhaust looks like:
Is this normal?? Im referring to the residue that has come out of it and deposited on the expansion chamber
Currently:
2012 Kymco Like70
72cc Malossi BBK
Dell'Orto PHBG 19 AS Carb
52 Pilot Jet
92 Main Jet
W7 Needle, 40 Slide
2T atomizer + bushing
Tecnigas Triops
Malossi Torque Driver
Re: How much "gunk" should be coming out of my exhaust?
November 19, 2013, 01:42:06 AM »
Depends on several factors... combustion temperature, oil/fuel mix ratio, jetting, spark plug...
245luigi
Sr. Member
Boston, MA
November 19, 2013, 03:24:02 PM »
Seem like something I should do more research in then. Anybody know of any resources?
FYI Im on stock br8hsa plug, stock oil mix (meaning I havent played with the pump settings at all), 88MJ and no idea as to my combustion temps
Currently:
2012 Kymco Like70
72cc Malossi BBK
52 Pilot Jet
92 Main Jet
W7 Needle, 40 Slide
Tecnigas Triops
Reply #3 on:
November 20, 2013, 01:48:28 AM »
Factory/stock fuel mix is ok... you need the lubrication... the idea is to burn all the oil in the combustion chamber so no oil goes out the pipe...
Back
