Author Topic: Starting Issue  (Read 907 times)
pauldavid1977
Starting Issue
« on: November 20, 2013, 02:14:20 PM »
Hello,
Recently, my less than 2 year old Agility 125 does not start.   The lights will come on and the fuel gauge will move but I hit the electric starter and I get nothing no signs of anything happening just silence.
Usually, when that happens I can kick start after a few kicks.  Sometimes after a few kicks the electric starter will work again.  Also, sometimes I just have to try the electric starter a few times before it works.   Sometimes it works for days without the issue and then it just comes back.
Any ideas?
tortoise
Re: Starting Issue
« Reply #1 on: November 20, 2013, 05:04:13 PM »
Since your query apparently reflects your lack of wiring diagram comprehension, and multi-meter testing aptitude . . this issue may be covered under the Kymco 2-year limited warranty.
Jim Moore
Re: Starting Issue
« Reply #2 on: November 21, 2013, 01:41:48 PM »
Sounds like you have a loose connection somewhere. Tighten the battery cables. Trace the battery cables to the other ends and tighten them too. You may just need a new battery. Two years isn't a long time, but it's not impossible that your battery is worn out.
Aceforever
Re: Starting Issue
« Reply #3 on: January 14, 2014, 07:16:48 PM »
Hello my friend,
Sounds to me you have a similar problem as I did last year. Any problems with the brake lever? Try using the other brake lever to start it and see what happens.
I thought the problem was a flat battery with my one but it wasn't. The mechanic said it was the brake lever not triggering once you press the started button.
