Author Topic: What are these electric leads for.....?  (Read 756 times)
« on: November 28, 2013, 04:47:36 PM »
The black plug is for the Kymco diagnostic tool plug-in...
But what are the other 2 leads for?
Found these while adding padding to my battery, to stop it from clunking around when I hit bumps (Kymco should have added a strap)
Thanks, Stig
GLV55
Re: What are these electric leads for.....?
« Reply #1 on: November 28, 2013, 09:37:11 PM »
That's where you plug in your hot plate and electric BBQ!  ;-)
2014 Lance PCH 150
2007 Kymco People 150 (totaled by a drunk, Oct. 2013)
Nampa, ID
Urbestfriend
« Reply #2 on: November 28, 2013, 09:40:15 PM »
The three Kymco's I've had have all had the Green Butt Connector,  but it's usually inside the front cowl.
« Reply #3 on: November 29, 2013, 05:16:05 PM »
Those two pink leads are to initialize the TPS and Air Bypass Valve. Service manual says to hook 'em together or ground one of them. Just checked the SM and you ground the pink lead with the plastic sleeve to either the frame or Battery - (minus). That is with the key on, engine not running.
« Last Edit: November 29, 2013, 05:20:03 PM by CROSSBOLT »
