Author Topic: Flyscreen rattle  (Read 818 times)
alphaBETAdog
Flyscreen rattle
« on: December 28, 2013, 03:07:34 AM »
I'm getting some sort of vibration rattle at low rpm that appears to be coming from the flyscreen. Anyone else getting this?  It is only at low throttle settings, and fairly annoying at a stop light, but goes away as the engine spools up. I've tried putting sections of foam weatherstipe tape between the flyscreen and upper cowling, but that hasn't really helped much. Thinking of trying a bead of clear silicon, but that seems like it might be a little too drastic.
Central Arizona
'12 Kymco GTi300
'03 Aprilia Scarabeo 150
'08 Beta RS450 Dualsport
'13 Suzuki Vstrom 650
Re: Flyscreen rattle
« Reply #1 on: December 28, 2013, 03:12:41 AM »
I've had that problem and I thought the same... tightened it but still won't go away... turned out to be a loose screw INSIDE the cowl...
